  • Sandtrap Motorsport
  • Member For: 16y 6m 25d
also did a few little things while I was doing oil pump gears.
got a few parts ceramic coated (waiting to pick up),
sump in the chrome coat
timing cover in the chrome coat
alternator in a blue candy.
will be getting more done, but I just got these done due to the fact its easier to do these the first time.
where as the rocker cover is easy to remove at a latter date.
same with the turbo, water pump, and some other trick parts that will get done. or have trick stuff on them.
anyways, as I said above, I got little things done while the the engine was "apart"
that included removing the water pump, and removing its impeller so I can run a inline electric CWP (craig davies electric water pump).
all I have to do is weld the 2 'holes' and it will be all ready to use. I also have to remove the thermostat, and block some of its lines/holes, but I can do that at a latter date
and more importantly, the car will be going to Allfast this coming Monday for the driveline to be fitted :D
will be bunking there with Matt's Turbo EF (which is getting a T400 fitted)
and here is the bling, but more importantly, it has a role to play. the big players in International drag racing ceramic coat their sumps to keep the heat IN the oil.
if you can have oil at temperature with a cold block, you make more HP :)
Edited by Tocchi
  • ...JD TUNING ADELAIDE...
  • Member For: 17y 19d
the ceramic coating is sexy as all hell nice work what did it cost for coatings?
  • Forged Member
  • Member For: 18y 4m 12d
Ahh, I get the hot oil cool motor thing, very cool tocchi, the Capri is gonna be a monster when you're done :blink:
getting the head, valves, pistons etc done on the built motor
all up, the sump and cover cost $400
  • Member For: 17y 1m 8d
whats the turn around time from when you send the parts to when you get them back when getting them coated. Was thinking of getting a few things done.
  Dillz said:
Damn I wish I had endless cash to through at a car.
I dont.. I just dont waste my money on pointless sh*t
I dont smoke, dont do drugs, dont waste $300 at clubs on weekends etc.
dont buy $400 designer sunglasses etc
10 days :)
  • Member For: 18y 24d
10 days :)
Damn I wish I had your state of mind, my philosophy is blow $300 on booze and strip clubs now and build expensive cars later, but that's just me.
Edited by Dillz
