  • 4 weeks later...
  • Sandtrap Motorsport
  • Member For: 16y 4m 21d
Small update: bottom end assembled. 360 thrust bearing done (king bearings used).
  • Like 6
  • Member For: 17y 4m 21d
Shiny things I don't understand....*clicks like*
  • Like 2
This engine is costing more than the total build cost of the wagon including vehicle purchase lol
Expand
Don't we all :)
  • Member For: 12y 12d
Looks the goods mate!! Love the filled block and 9/16 studs.. I commented on your Facebook post on sand trap motorsports yesterday
I probably missed it but a few quick questions..
what rods are you using?
Looks like the mahle Pistons?
Have you thought about what head gasket your using?
What turbo do you have to go on it?
Any head work?
Cams?
Ecu?
Any head work?
Cams?
Ecu?
Cheers :) ah yes :)
Rods = spool pro drag I beams - iirc
Pistons = mahle powerpak 0.003" over, with coating
Head gasket - no idea yet, have an OEM MLS gasket - as I'm welding up the head and using 14.3mm head studs, the factory gasket should be ok :)
Turbo = precision pt6870 replacing the t51
Headwork = whatever is required to support the atomic battlemaster cams :)
Running a motec m800 ecu
Oh the old 306620 and 306564, I'll hook you up
Just letting everyone know Tochhi has asked me to supply the timing gear for this build because I'm a perfeshunal enjun maker!!!!1!
So if it fucks up and explodes he can blame me :)
