Crapri Drag Car
Tocchi
  • Sandtrap Motorsport
  • Member For: 16y 2m 25d
On Friday I had Luke (Ralphy) calibrate the 2-Bar BA/BF Turbo TMAP to the PCM,
I've been running the 0.4-Bar Non-turbo TMAP, which was OK for a short term fix as it kept the boost down, but made it impractical, due to boost cut at 0.4-Bar & cold starting was an issue as the AIT was out of whack with the minor PCM changes for turbo base map ... With the TMAP calibrated, cold starts are great.
Luke and I were also left with the ETC fault, we thought it was to do with the boost cut, but upon some digging around on HP Tuners software, Luke discovered it was due to the FG parameters being used on the FG Throttle Body, so with a quick change to BF TB parameters, the ETC fault was eliminated and wagon became useless in the wet even with the 275 Kumho's on it haha
  • Like 2
  • Member For: 17y 2m 25d
The mark of a true boosted Falcon
Changed radiator, expansion bottle & coolant types today, went Toyota pink.
While I was getting distracted I removed front bar, remounted my horn (wasn't connected), fixed a headlight connector and secured some wiring harnesses better.
Nothing crazy but just good to get those done before summer really starts heating up
Ahh that nizpro cooler
Pinkkk
Back on
Just a brand I purchased to test how the 245/45/R17 fitted... Didn't want to buy unusual sized quality tyres only to find they don't fit & are hard to sell.
When the car was N/A it was running green tectaloy spec coolant ... Upon turbo conversion, I ran demineralised water (for a few flushes) to remove all the green elements.
I was going to go Toyota red (the concentrate) but I Cbf doing the 50:50 mix manually, so I bought the pink coolant which is 50:50 premix
