  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 17d
360 degree thrust bearing lol ?
How do u like the prodrag 6 CDI coupled with stock coils ?
Were going to use the prodrag 6 but M&W standalone coils and lead combo
What boost is it going to run ?
  • Sandtrap Motorsport
  • Member For: 16y 4m 23d
360 degree thrust bearing -- haven't looked into it, I have never had a built Barra before, could you quickly fill me in on that please?
The prodrag6 works GREAT with the stock coils. There are lightening bolts coming out ! :)
It ran 28psi on the old tech T51 (journal bearing), 5900rpm limiter, methanol, glide & stall, slicks & 9" on dyno... pumped out 680hp
With this new setup, we will aim for 500rwhp (so I can learn the new setup and get licenced), will be good for mid 9s, so what would that be, like 15psi on this efficient setup? maybe less ... as it will rev to 7,500rpm ish ?
we shall be going for a BIG power figure on the dyno though... if anything, for raceteam advertisement for potential sponsors
Have a word to luke as he will fill u in on the bearing and why you will need it ;)
Interesting indeed
Looks like were going for a promod91 ( maybe ) so were ideally under 30psi but need that super clean spark also
Might keep the stock coils in mind to try first
Luke messaged me I need it ... so I most certainly need it haha
any idea of the going rate for them? or who manufactures them?
oh that is a big dirty turbo at a lot of psi :D
Hope I helped as were going through it now also on another build
  • in the mid....not the bum like some
  • Member For: 11y 11m 25d
I had the 360 fitted to my engine its for cars with high stalls and when loading converter for extended periods of time.
It use to be a factory fitment but was stopped after the EL Falcon.
You can also get a extra side main cap bolt fitted so each side has 5 of them.....Brad can enlighten you more also on this.
  • Like 2
Brad has got back to me, very pleased
Always has time to answer questions. Total champ.
  • Like 4
