  • Member For: 12y 26d
  On 02/10/2015 at 10:34 AM, Tocchi said:
Any chance you could measure their thickness?
According to my super fancy $5 fleabay micrometer thingy... 25.5mm one rotor and 25.6mm other.
Think they are 26mm new from factory...
  • Member For: 16y 11m 4d
  On 02/10/2015 at 7:23 AM, PTR_NITRO_FG said:
Oh and what's that Matt....you want to buy my RDA rotors for $100? (with 700ish kms use since last machined) :P
http://www.gumtree.com.au/s-ad/tuart-hill/brakes-suspension/territory-f6-bf-mkii-fg-rda-rear-rotors-328mm/1091031219
Yes that's my ad Phil lol
Matt....check with old mate Wiggum, but I thought it was 2mm max wear....so 24mm?
Its not written on hat area like OEM...and I don't have standard rotors to check (cause I bought calipers/lines only).
  • Sandtrap Motorsport
  • Member For: 16y 6m 26d
That's ok - I'll live with that haha.
If you can do free delivery to wanneroo I'll buy them :)
I thought it was 28mm and minimum of 26mm?
Do a lap around the outside of one of the discs with a drill and wire brush - it might be written on the outside.
ok guys, thought it's been a while between Capri posts.
tldr: still waiting on engine and transmission -- the workshops have been busy, but I have not been on their case (I have, but not ASAP kinda thing) as I have been on "redundancy notice" for half a year now. haha. BUT I am tired of waiting, so im wanting it going asap.
revised engine build parts list. lol
Bottom end:
Mahle Powerpak Plus pistons 0.003” (with heat coating on tops & skirts)
Spool Pro Drag I-beam rods
FG block – grout filled
BF crank – cryo treated, machined & balanced by Harris Engines, Isotropic polished by CIC)
Atomic Performance Induction hardened crankshaft sprocket (#306562)
Atomic Performance Chrome Moly Flexplate (#306720)
Atomic Performance Oversize Head Dowels (#306130)
Atomic Performance ARP 14.3mm Head Stud kit with oversize washers (#306653)
Atomic Performance 16mm Main cap race girdle & windage tray (#306250)
Atomic Performance Main stud kit kit (#306670)
High Speed Engineering oil pump gears
Ross Full Metal Jacket Balancer (with drive pulley attachment)
FG sump with custom baffling & extended oil pickup
Head / timing:
BA XR6T head – welded up, cooling circuit running through it, stock valves so far
Davies Craig Electric Booster Pump 23L/min (to circulate head coolant)
BA F6 rocker cover with -16 breathers welded on
Atomic Performance Stage 5 BattleMaster Duo Phased cams (#306552)
Atomic Performance VCT blank off plates (#306740)
Atomic Performance Chrome moly vernier adjustable cam sprockets (#306560)
Atomic Performance Anti Pump Hydraulic Lifters DOHC (#306520)
Atomic Performance Ovate Race Valve Springs 115 Lb @ 1.490” (#306802)
Atomic Performance Valve Spring Retainers, Titanium (#306851)
FG intake manifold
BBK Mustang 75mm throttle body
Atomic Performance Chrome moly timing guide pivot and M8 locknut (#306564)
Atomic Performance Heavy Duty Single Row Roller timing chain (#306620)
Atomic Performance Heavy duty Hydraulic-over-mechanical timing chain tensioner (#306563)
Permaseal MLS head gasket
Turbo setup:
Ovaboost (6 boost collector) turbo manifold
Precision PT6870 (1.0 AR)
Tial 60mm gate
4.5" dump and 2" screamer, venting behind front wheel.
Fuel:
Process West -10 dual feed fuel rail
Bosch ID2000's x 6
Magnafuel 4 port boost referenced fuel reg
Aeromotive #11105 Mechanical Fuel pump
Aeromotive -10 check valve
Magnafuel 40 micron stainless filters
Electrics / Ignition:
Stock Visteon coilpacks and plugs - they work the best
M&W Prodrag6 CDI unit.
Eboost2
Motec M800
Edited by Tocchi
  • Like 4
