Tocchi Sandtrap Motorsport Donating Members 2,055 Member For: 16y 1m 24d Gender: Male Location: Perth Posted 02/10/15 06:52 AM Author Share Posted 02/10/15 06:52 AM fitting those calipers might require a hammer good stuff Lol actually possible given I may need a mallet to knock the old rotors off ... These are the territory 328mm setup ... Just need to source some rotors Link to comment Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 1m 28d Gender: Male Location: Brisbane Posted 02/10/15 07:05 AM Share Posted 02/10/15 07:05 AM Apparently, those slide bolts are to be replaced everytime you do pads.....I never have..probably why my diff bush keeps splitting..Does anybody replace them erry time? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,142 Member For: 16y 9m 7d Gender: Male Location: Melbourne Posted 02/10/15 07:09 AM Share Posted 02/10/15 07:09 AM nope... if you mean the self-adjusting bolts. Link to comment Share on other sites More sharing options...
PTR_NITRO_FG Donating Members 3,214 Member For: 11y 7m 23d Gender: Male Location: NOR Perth Posted 02/10/15 07:23 AM Share Posted 02/10/15 07:23 AM These are the territory 328mm setup ... Just need to source some rotors You going to get them rebuilt? Or am I the only sucker whos done that lol ...."my FG has 30,000kms and I needed to rebuild them" ... "the problem with buying wrecked calipers is you never know how long they have been sitting around, with old brake fluid slowly damaging the insides" etc etcOh and what's that Matt....you want to buy my RDA rotors for $100? (with 700ish kms use since last machined) Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 3m 25d Gender: Male Location: Perth Posted 02/10/15 07:42 AM Share Posted 02/10/15 07:42 AM Apparently, those slide bolts are to be replaced everytime you do pads.....i never have..probably why my diff bush keeps splitting..Does anybody replace them erry time?The smaller 8mm bolts that secure the caliper to slides are supposed to be replaced each time....but only because they have factory loctite.if you clean off the loctite and use fresh goo and torque correctly they are fine. 2 Link to comment Share on other sites More sharing options...
Tocchi Sandtrap Motorsport Donating Members 2,055 Member For: 16y 1m 24d Gender: Male Location: Perth Posted 02/10/15 08:43 AM Author Share Posted 02/10/15 08:43 AM Didn't know about the bolt thing, but everytime I do what Luke has just posted, so no dramas ahead I see.Oh and what's that Matt....you want to buy my RDA rotors for $100? (with 700ish kms use since last machined) So they're new and have done 700km or have a lot of kms and had a skim 700km ago?I can get new ones from my contact for a very good price (ie: under trade) so unless they are very new, I'd have to pass ... Unless $50 will get rid of them? Then I'll use them for mockup Link to comment Share on other sites More sharing options...
PTR_NITRO_FG Donating Members 3,214 Member For: 11y 7m 23d Gender: Male Location: NOR Perth Posted 02/10/15 09:20 AM Share Posted 02/10/15 09:20 AM Nah sorry homie.....@ $50 I'd rather keep them if I ever decide to sell the car...they are used (15,000-20,000kms) and I skimmed them and used for 700ish kms (Ruke said go easy first 1,000kms). Then my OCD didn't like the look of T3 fronts and RDA rears lol If you can get under trade price then that's the way to go... (I paid like $180 or something IIRC); but if you're a fussy karnt like me, then just go T2 rears ($270ish? but I'm sure you have a hook up for them too ) yay updates! Link to comment Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 5m 12d Gender: Male Location: Adelaide Posted 02/10/15 09:53 AM Share Posted 02/10/15 09:53 AM The smaller 8mm bolts that secure the caliper to slides are supposed to be replaced each time....but only because they have factory loctite.if you clean off the loctite and use fresh goo and torque correctly they are fine.luke is that the same as the front bolts. I did notice loctite on them but didn't replace it but I did crank them tight. Ill have a stab at the rears sunday. So loctite the bolts you remove to release the caliper centre to remove the pads? Link to comment Share on other sites More sharing options...
Tocchi Sandtrap Motorsport Donating Members 2,055 Member For: 16y 1m 24d Gender: Male Location: Perth Posted 02/10/15 10:34 AM Author Share Posted 02/10/15 10:34 AM Nah sorry homie.....@ $50 I'd rather keep them if I ever decide to sell the car...they are used (15,000-20,000kms) and I skimmed them and used for 700ish kms (Ruke said go easy first 1,000kms). Then my OCD didn't like the look of T3 fronts and RDA rearsI have to take gumtree lowball mode off? Dammit lol. Any chance you could measure their thickness?Haha I'm not that bad with OCD.Currently have a 3K stall in my BTR, that beats a rotor mismatch on my OCD meter haha 1 Link to comment Share on other sites More sharing options...
velocityxr6t Member 122 Member For: 16y 2m 4d Gender: Male Posted 02/10/15 09:34 PM Share Posted 02/10/15 09:34 PM luke is that the same as the front bolts. I did notice loctite on them but didn't replace it but I did crank them tight. Ill have a stab at the rears sunday. So loctite the bolts you remove to release the caliper centre to remove the pads?Loctite all caliper mounting bolts. They can rattle loose. Anytime you work on brakes have loctite handy. 1 Link to comment Share on other sites More sharing options...
