blueboost Member 1,204 Member For: 20y 9m 11d Gender: Male Location: Mackay NorthQueensland Posted 10/02/09 07:08 AM Share Posted 10/02/09 07:08 AM (edited) be good to see, I did not think the Capri would have the under bonnet clearance. David Edited 10/02/09 07:09 AM by blueboost Link to comment Share on other sites More sharing options...
BFHOON Donating Members 1,932 Member For: 18y 11m 13d Gender: Male Location: nsw Posted 10/02/09 07:21 AM Share Posted 10/02/09 07:21 AM (edited) just a thought, with the intercooler setup, have you considered using a dry ice setup.being a drag only application the shorter intake path with an ice box would be ideal.not too hard to diy.also nice work, puts you in a lower class with a six, isnt there a 4.0 litre class in andra now. Edited 10/02/09 07:23 AM by BFHOON Link to comment Share on other sites More sharing options...
Guest Guests Posted 10/02/09 07:23 AM Share Posted 10/02/09 07:23 AM Would be ideal for a drag car & reduce intake temps severely! Link to comment Share on other sites More sharing options...
BFHOON Donating Members 1,932 Member For: 18y 11m 13d Gender: Male Location: nsw Posted 10/02/09 07:35 AM Share Posted 10/02/09 07:35 AM I have seen temps as low as -30c mid run on a sr20 equipt datto, on the data logging on the return drive from the run to the pits it was still -10.this allows for more timing to be added allowing in some cases 50% more power than at +20.c. Link to comment Share on other sites More sharing options...
SCRIBR Yaris member Member 4,486 Member For: 18y 8m 16d Gender: Male Posted 10/02/09 08:00 AM Share Posted 10/02/09 08:00 AM +50% Link to comment Share on other sites More sharing options...
Tocchi Sandtrap Motorsport Donating Members 2,055 Member For: 16y 3m 12d Gender: Male Location: Perth Posted 10/02/09 08:05 AM Author Share Posted 10/02/09 08:05 AM be good to see, I did not think the Capri would have the under bonnet clearance.Davidcustom chassis, and front of the car is a 1 piece fibreglass mould.so it should fit, and if it doesnt. jigsaw time just a thought, with the intercooler setup, have you considered using a dry ice setup.being a drag only application the shorter intake path with an ice box would be ideal.not too hard to diy.also nice work, puts you in a lower class with a six, isnt there a 4.0 litre class in andra now.yeh ive been looking at that, will help with not having to cut front open too so a lower class... I thought id be racing in EFI or SS/BBor am I wrong?I have seen temps as low as -30c mid run on a sr20 equipt datto, on the data logging on the return drive from the run to the pits it was still -10.this allows for more timing to be added allowing in some cases 50% more power than at +20.c.cant argue with results is this the kind of this I should be looking at? if so, what brands should I look at?http://www.pwr.com.au/coolers_atoi.htmlAir to "Ice" Barrel Intercooler The NEW Air to "Ice Barrel" intercooler uses PWR's revolutionary seamless round leading edge tube design with internal fin, which incorperates a straight through design improving heat transfer for less pressure drop.The New Air to "Ice Barrel" utilises a unique straight through tube arrangement like the "Liquid to Air" Barrel design, however the "Ice Barrel" is designed specifically to run ICE and incorperates wide 18mm Tube Pitch, a Finless Ice compartment, sealed access lid and CO2 Breather fiting which gives this unit a unique design and the first available in the market. Link to comment Share on other sites More sharing options...
Mike XR6T iTs alL DaRDy........ Donating Members 780 Member For: 17y 6m 4d Gender: Male Location: Adelaide Posted 10/02/09 08:35 AM Share Posted 10/02/09 08:35 AM gonna be sexy as mate, post us some pics of the install hey! Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 1m 2d Gender: Male Location: SW Sydney Posted 10/02/09 09:20 AM Share Posted 10/02/09 09:20 AM Very nice Tocchi - keen to see what it does with the stock motor, thn what she can turn out with a big built motor! Link to comment Share on other sites More sharing options...
Chich Damn You's A Sexy Chich Member 3,843 Member For: 17y 21d Gender: Male Location: Your House Posted 10/02/09 09:30 AM Share Posted 10/02/09 09:30 AM looks like an interesting project you got underway, make sure you get plenty of progress photo's up as she comes along Link to comment Share on other sites More sharing options...
BFHOON Donating Members 1,932 Member For: 18y 11m 13d Gender: Male Location: nsw Posted 10/02/09 09:49 AM Share Posted 10/02/09 09:49 AM that's what I was talking about , the one I saw was a bit bigger but basicly the same. Link to comment Share on other sites More sharing options...
