  • Sandtrap Motorsport
  • Member For: 16y 7m 8d
sneak peak photo. dont want to give away too much yet
its a depressing 4.5" dump pipe there.
1.5" pipes on the manifold.
T51
the wastegate port has to be done on the rear housing in the photo, was done at the base due to it being a twin scroll turbo
yeh same :P
just trying to get a hold of the workshop (late friday arvo -- good luck :P) to find out what hose I need for the oil supply line.
factory oil supply came off the sender aye?
either Dash-4 or Dash-6?
  • Moar Powar Babeh
  • Member For: 19y 9m 10d
factory was dash 3.5 (5MMISH ID) you want -4. Are you keeping the pressure switch in that location? cant tell you what size banjo you need if you are.... :bangcomputer:
nah im running mechanical gauge, so it will be a T-piece into the block (where switch/sender goes). one line goes to gauge, the other to turbo.
unless theres something wrong with doing it that way?
  • Moar Powar Babeh
nope no problem at all. As long as any turbo oil pressure inlet restrictor orifices are in place on the turbo (if required)
to think I was worried about my chassis holding up to the power of the 6T.
thinking the only motor its has was the 650flyHP clevo 383 N/A
turns out the previous owner had a supercharged small block and it ran 7s.. fills me with more confidence with the car :)
theres not much to do now:
buy tyres for tuning (MT sportsman or something)
buy Motec MSDL dash -- not needed at the moment, one of those "in the future" purchases
make up pipe for throttle body
make the wastegate port still has to be done (I think), then make the screamer pipe (easy)
intall the Atomic Ovate styled valve springs
oil lines for turbo
wire up motec, and tune.
unless im missing something obvious, then theres not much to do.
unsure what im going to do with panel & paint now, as my painter (BBK) has stopped painting and started selling paint as a supplier.
eeeeep :(
