koppers Member 119 Member For: 18y 5m 23d Posted 02/02/09 11:12 AM Share Posted 02/02/09 11:12 AM (edited) Edited 03/02/09 12:04 AM by Dagabond Link to comment https://www.fordxr6turbo.com/forum/topic/54162-on-the-dam-in-the-t-cat/ Share on other sites More sharing options...
Panda Eyes flame magnet Gold Donating Members 5,674 Member For: 17y 23d Gender: Male Location: adelaide hills- 'race air' central Posted 02/02/09 11:29 AM Share Posted 02/02/09 11:29 AM I want that 14 secs of my life back... Link to comment https://www.fordxr6turbo.com/forum/topic/54162-on-the-dam-in-the-t-cat/#findComment-815504 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 16d Gender: Male Location: Perth Posted 02/02/09 11:34 AM Share Posted 02/02/09 11:34 AM whats the best ever Mike Tyson quotes on the same pages. The 14sec is worth that! Link to comment https://www.fordxr6turbo.com/forum/topic/54162-on-the-dam-in-the-t-cat/#findComment-815508 Share on other sites More sharing options...
koppers Member 119 Member For: 18y 5m 23d Posted 02/02/09 11:37 AM Author Share Posted 02/02/09 11:37 AM fordriver1 said: I want that 14 secs of my life back...Ease up. If you didn't like it, keep your comments to yourself.For those that care, the motor (70 hp CES Yamaha) is one of only 2/3 in the country, and testing at the moment has seen 110 km/h with an 18p cleaver. When the 24p prop is put on we're hoping to see over 12o km/h.Lots of fun for something that has <150kg total weight. Link to comment https://www.fordxr6turbo.com/forum/topic/54162-on-the-dam-in-the-t-cat/#findComment-815511 Share on other sites More sharing options...
Panda Eyes flame magnet Gold Donating Members 5,674 Member For: 17y 23d Gender: Male Location: adelaide hills- 'race air' central Posted 02/02/09 11:38 AM Share Posted 02/02/09 11:38 AM (edited) it's not that I didnt like it. I guess with half the vids on here being funnier than the last, it was just different than I expected.part of being in a forum is accepting all comments, positive or otherwise, dude. Edited 02/02/09 11:40 AM by fordriver1 Link to comment https://www.fordxr6turbo.com/forum/topic/54162-on-the-dam-in-the-t-cat/#findComment-815513 Share on other sites More sharing options...
qik1 Silver Donating Members 2,720 Member For: 17y 28d Gender: Male Location: Loitering in SEQ Posted 02/02/09 11:40 AM Share Posted 02/02/09 11:40 AM what revs is it pulling with the 18??? Link to comment https://www.fordxr6turbo.com/forum/topic/54162-on-the-dam-in-the-t-cat/#findComment-815514 Share on other sites More sharing options...
koppers Member 119 Member For: 18y 5m 23d Posted 02/02/09 11:56 AM Author Share Posted 02/02/09 11:56 AM qik1 said: what revs is it pulling with the 18???Just under 7100 rpm. Still working on height off the deck and trim. A guy in the states custom makes a hybrid 70 and pulls 7500 rpm with 20p cleaver @ 123 km/h! Link to comment https://www.fordxr6turbo.com/forum/topic/54162-on-the-dam-in-the-t-cat/#findComment-815530 Share on other sites More sharing options...
qik1 Silver Donating Members 2,720 Member For: 17y 28d Gender: Male Location: Loitering in SEQ Posted 02/02/09 12:14 PM Share Posted 02/02/09 12:14 PM (edited) I take it that theres obviously been some major internal work to allow this thing to rev as they only have a rev limiter of about 6k from the factory crankshaft, porting, carbies, reeds, compression ratio played with, etc etc . Do ya run it on ulp or a avgas high octane fuel? Obvioulsy weight reduction, revs & the " of prop is allowing speed like this from a reasonably small outboard but how do you go putting it into a corner with having to run the motor so high. Does it cavitate or blow out? How do yas expect to run a 24' prop are you going to modify the gear ratios some how??? Edited 02/02/09 12:17 PM by qik1 Link to comment https://www.fordxr6turbo.com/forum/topic/54162-on-the-dam-in-the-t-cat/#findComment-815545 Share on other sites More sharing options...
koppers Member 119 Member For: 18y 5m 23d Posted 02/02/09 12:34 PM Author Share Posted 02/02/09 12:34 PM The 70 ces short shaft is a factory made race-spec motor out of South Africa for races such as the Trans Agulhas. I'd hazard a guess at saying that there would be no more than 50 originals or so floating around world-wide. It's a pretty serious bit of kit, be fair to say it'd have 50% again more power than your normal standard leg 70 Yamaha. It spins the 18p without a worry in the world, no bog into corners, the torque of the thing in comparison to the 50 hp motors can't be compared. The motor was bought off an ex racer from SA who had it on a rib running a a reduced custom gear-set. WHich comes in handy as you've noted when needed to spin such a big prop.Have already had the 24p on the 50 (race sealed) and spun that to 6200 @ ~95 from memory.Lots of fun! Link to comment https://www.fordxr6turbo.com/forum/topic/54162-on-the-dam-in-the-t-cat/#findComment-815557 Share on other sites More sharing options...
qik1 Silver Donating Members 2,720 Member For: 17y 28d Gender: Male Location: Loitering in SEQ Posted 02/02/09 12:46 PM Share Posted 02/02/09 12:46 PM I bet it is. I figured it had to be an import as I couldnt remember there being a factory optioned animal like this. Would be fun to look inside to see what they have done. We've stuffed around with stuff abit bigger way back, the logistics of making even a factory race spec motor do what it did & still see enough reliability to finish multiple races was no mean feat. Its fun while it last but it can hurt the pocket. with them that highly strung theres always gonna be problems along the way. I spose no different to our car in that respect. Link to comment https://www.fordxr6turbo.com/forum/topic/54162-on-the-dam-in-the-t-cat/#findComment-815564 Share on other sites More sharing options...
