fordfreak XRT07 Member 378 Member For: 16y 6m 25d Gender: Male Location: glenwood Posted 01/02/09 03:14 PM Share Posted 01/02/09 03:14 PM Hello.. im matt.. some may know me form Fordmods.com having owned a 176rwkw max NA white efa fairmont that rolled on 20's..ages ago I started my account on here.. however only over the last 2-3 weeks have I started posting..6 months ago I baught myself this ex "tamworth country chaser"... an...07 BF MK11 XR6 TUBRO...."Breeze"6 speed ZF..reverse sensors..big brake upgrade..$21,990 with 82,000 on the clock.. with a good service history.. have replaced the waterpump under warranty and that's it.. she's at 98,000km now...mods so far...polished brake calipers by me...polished and detailed ecu cover..rear quad section.. $150.. (ebay)installed for $150 inc high temp black sprayed.. spot welded.. a hanger welded!!!! DJR 230 Bobtail spoiler..de-badged..225/30/20 fronts.. 255/30/20 inch rears...fairmont dash clock added..chrome interior fairlane door handles..jetspeed fibreglass bonnet bulge..double ea centre point snorkle's out the front of the lower airbox the same as the typhoon rubber snorkle..and that's it................................................................. SO FAR!!!!! Link to comment Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 7m 15d Gender: Male Location: Earth Posted 01/02/09 03:26 PM Share Posted 01/02/09 03:26 PM (edited) The big brake upgrade doesn't look very big to me.What did you upgrade? Edited 01/02/09 03:28 PM by PHANTMXR6 Link to comment Share on other sites More sharing options...
fordfreak XRT07 Member 378 Member For: 16y 6m 25d Gender: Male Location: glenwood Posted 01/02/09 03:35 PM Author Share Posted 01/02/09 03:35 PM I did not touch the brake apart from polishing them.. slotted rotors were allready there.. and they do loook smaller behind 20's!!! with the stock 17's on they filled the tyre nicely... twin pot fronts..oh.. and at WSID middle of last winter..no spare tyre..half a tank of fuel..stock 17's..me 80KG's..pulled consistent 13.3 flats at 105 - 107.54 MPH2.0 sixty footer's.. with usualy 0.1 - 0.25 reation time's... Link to comment Share on other sites More sharing options...
typhoon_freak Cryptic Clothing Company Donating Members 4,556 Member For: 16y 6m 24d Gender: Male Location: Brisvages, Capalaba Posted 01/02/09 07:43 PM Share Posted 01/02/09 07:43 PM that's pretty fast for a stock xr6t. good work mate Link to comment Share on other sites More sharing options...
fordfreak XRT07 Member 378 Member For: 16y 6m 25d Gender: Male Location: glenwood Posted 02/02/09 01:39 PM Author Share Posted 02/02/09 01:39 PM she is an ex chaser.. although im unsure what has been done/modified to make her slightly faster??? a factory flash tune??will be dyno'sing her this saterday with the "fordmods.com crew at penrith.. her first dyno day... im so keen to see what she puts out at the rear wheels.. Link to comment Share on other sites More sharing options...
Dirty32 Legendary member!! Donating Members 1,739 Member For: 18y 12d Gender: Male Location: Dianella, West Oz Posted 03/02/09 02:32 PM Share Posted 03/02/09 02:32 PM The polished calipers came out ok dude! Well done...Welcome! Link to comment Share on other sites More sharing options...
fordfreak XRT07 Member 378 Member For: 16y 6m 25d Gender: Male Location: glenwood Posted 04/02/09 12:37 AM Author Share Posted 04/02/09 12:37 AM thanks!!! took me 2.5 hours to do each front caliper...1.5 hours to do each rear caliper...all by hand!... a very messy job.. I was grey all over my face and hands!.. thought I'd attempt this mod as it is far too easy to slap on some paint and wanted to stand out just a little bit... Link to comment Share on other sites More sharing options...
fordfreak XRT07 Member 378 Member For: 16y 6m 25d Gender: Male Location: glenwood Posted 09/02/09 11:10 AM Author Share Posted 09/02/09 11:10 AM just had her dynoed on saterday Sydney Penrith.. at 1pm.. was on 40 degree's!!!! and I ran my stock 255/30/20 inch rims all round.. no steellies on the dyno...she ran 225RWKW... how many % loss through a zf 6 speed auto?? about 20%?? if so.........adding 20% ontop of 225 RWKW gives 270KW at the engine... does that sound right?? she does run flat 13.3's at 107.54 MPH.. 2.0 sixty footers... I was extremely happy with the figure in the heat wave of 40 degree's with big rims on... Link to comment Share on other sites More sharing options...
RSK Member 340 Member For: 17y 4m 21d Gender: Male Posted 11/02/09 09:04 PM Share Posted 11/02/09 09:04 PM I like the polished brakes. How did you go about polishing them? Link to comment Share on other sites More sharing options...
fordfreak XRT07 Member 378 Member For: 16y 6m 25d Gender: Male Location: glenwood Posted 12/02/09 10:18 AM Author Share Posted 12/02/09 10:18 AM 2. 5 hours on each front caliper.. 1.5 on each rear caliper...be prepared to spend some time on them!!...*start by using a flapper wheel attached to a high speed power drill.. (off main power) no battery..*sand down all the rough casting to a semi smooth surface..*then start with 80 grit sand paper for 10 mins.. then 120/200/400/800/1000/1500/2000/2500 then autosol polish... Link to comment Share on other sites More sharing options...
