DesFlurane Member 351 Member For: 19y 1m 14d Gender: Male Posted 01/02/09 02:23 AM Share Posted 01/02/09 02:23 AM What exactly is this?Have seen it mentioned a few times.Who would it be appropriate for?Thanks. Link to comment https://www.fordxr6turbo.com/forum/topic/54098-high-flow-your-turbo/ Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 3m 26d Gender: Male Location: SW Sydney Posted 01/02/09 02:29 AM Share Posted 01/02/09 02:29 AM I think on here most people are talking about the modification of the wastegate port and flapper. This mod allows greater control at higher boost levels when coupled with a stronger wastegate actuator.I would recommend this mod to anyone looking at running higher than 10psi Link to comment https://www.fordxr6turbo.com/forum/topic/54098-high-flow-your-turbo/#findComment-814347 Share on other sites More sharing options...
rboksic Donating Members 514 Member For: 21y 1m 4d Posted 01/02/09 05:28 AM Share Posted 01/02/09 05:28 AM from my failing memorythe inlet housing on the turbo is opened up a bit on the squish face (?) to allow more flow Link to comment https://www.fordxr6turbo.com/forum/topic/54098-high-flow-your-turbo/#findComment-814494 Share on other sites More sharing options...
Ricky N Member 93 Member For: 16y 2m 10d Gender: Male Location: QLD Posted 03/04/09 11:27 PM Share Posted 03/04/09 11:27 PM DesFlurane said: What exactly is this?Have seen it mentioned a few times.Who would it be appropriate for?Thanks.Hiflowing a turbo usually means you are putting a bigger compressor wheel and/or turbine in the standard turbo housings.The only hiflow for the XR6's I know of that turbo shops are doing is the T04Z comp wheel onto the factory GT35R turbine. Machining standard comp cover to suit. Link to comment https://www.fordxr6turbo.com/forum/topic/54098-high-flow-your-turbo/#findComment-854958 Share on other sites More sharing options...
