X-WING Member 811 Member For: 21y 1m 25d Location: BRISBANE Posted 13/04/11 11:26 AM Share Posted 13/04/11 11:26 AM Hi gents,With 46000km on the clock with a fairly well looked after car my bushes are due for replacement.centre 1 stuffed. At what km is it normally expected. Been quoted 600 from local diff rep 700 from ford. Under advice I’m told the new ford replacement part is prob the best option nicer ride less likely to squeak ECT.Any thoughts on this greatly appreciated Link to comment Share on other sites More sharing options...
trevs Member 781 Member For: 17y 9m 7d Gender: Male Location: balmain Posted 05/07/11 09:20 AM Share Posted 05/07/11 09:20 AM hello ppl can anyone who has cut a hole in the boot well tell me when getting the old bush out was the cars weight still on the wheels or jacked up wheels off the ground when removing the old bush just trying to plan my job befor I start on the weekend to take as little time as possible installing the new bush also whats the best size hole ppl have found if I make it the 5mm bigger than the bush should that be enough cheers trev Link to comment Share on other sites More sharing options...
bigmat Donating Members 87 Member For: 17y 7m 24d Gender: Male Location: Gisborne NZ Posted 20/12/11 08:32 AM Share Posted 20/12/11 08:32 AM Well I just had mine done on my 07 Rspec BF (Ford haven't fixed the problem with the BF either), worst part the Ford dealer are trying to charge me $600 labour and $450 parts plus also found the passenger side wheel bearing was loose, Ford Mechanic said the axle lock nut had never been tightened properly from new. this was another $131 in parts and another $100 labour, I have been complaining about this noise in the diff for the last 3 years the dealer has never picked up what the problem was. I am bringing this up with Ford NZ if I have no luck with the dealer taking some responsibility for this whilst the car was under warranty.. (funny how they can find it outside of warranty). Link to comment Share on other sites More sharing options...
Brand Member 19 Member For: 16y 4m 21d Posted 30/06/12 06:05 AM Share Posted 30/06/12 06:05 AM Does anyone that has done this, think ud be able to change the diff hat at the same time?? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 5d Gender: Male Location: Perth Posted 30/06/12 09:19 AM Share Posted 30/06/12 09:19 AM IMHO, if you doing the rear bush you should also replace the two front diff mounting bushes. In doing this you need to remove the two outriggers from the diff, once they are removed the only thing retaining the diff in the cradle is the drive shafts, if you remove the upper control arm inner bolts you can swing the hub carrier out and lever the CV's out of the housing. The diff will then lift out.If you go to that extent, replace the diff output seals as well (only about $7ea from Ford) Changing the hat would only ad aprox 1hr to the time taken to replace the bushes. You could even stand the diff on the input flange and change the hat without replacing the diff oil, but you'd need to be a muppet to do that! 1 Link to comment Share on other sites More sharing options...
My_XR6_Turbo Member 282 Member For: 20y 5m 26d Posted 04/06/17 11:55 PM Share Posted 04/06/17 11:55 PM Has anyone used any of these before? Looks more solid than the OEM. http://www.ebay.com.au/itm/POLYPRO-FORD-FALCON-BA-BF-REAR-DIFFERENTIAL-MOUNT-CENTRE-BUSH-02-08-BUSHING-/131827851125?hash=item1eb18d5f75:g:I40AAOSwepZXRpW7 http://www.ebay.com.au/itm/SUIT-FORD-FALCON-BA-BF-REAR-DIFFERENTIAL-MOUNT-CENTRE-BUSH-NOLATHANE-49187-/232174762699?hash=item360eb1bacb:g:SJ8AAOSwEzxYSI4P http://www.ebay.com.au/itm/SUPER-PRO-FORD-FALCON-SEDAN-BA-BF-DIFF-CENTER-REAR-SUPPORT-BUSH-KIT-SPF2654-70K-/222324482538?hash=item33c39261ea:g:XnoAAOSwa~BYNkbJ Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 3m 1d Gender: Male Location: Perth Posted 05/06/17 01:34 AM Share Posted 05/06/17 01:34 AM Have the nolathane in my territory. Quite as s mouse. Not sure if I would use it in a high powered car. To much deflection Link to comment Share on other sites More sharing options...
