ravenhard Donating Members 1,517 Member For: 16y 11m 15d Gender: Male Location: Blacktown! Posted 24/02/09 06:47 AM Share Posted 24/02/09 06:47 AM for $450 it was replaced with a ford BF version which was supposed to be better. Who knows I probably got ripped but at least it has stopped clunking Link to comment Share on other sites More sharing options...
bda12pleaseu Member 94 Member For: 17y 1m 30d Gender: Male Location: newcastle Posted 25/02/09 08:02 AM Author Share Posted 25/02/09 08:02 AM So does this diff bush replacement fix the "diff clunks"???oh sheet yeah I think most would agree.... Link to comment Share on other sites More sharing options...
troydv Member 12 Member For: 15y 8m 25d Posted 13/07/09 12:20 PM Share Posted 13/07/09 12:20 PM Hey guys,So I bit the bullet and gave it a crack. I used to pedders Bush and spend the best part of 2 days getting it done. Worst part is defiantly undoing the bolts (as I had no ramps, just squeezed under!). The next was getting the old bush out. Used the technique described, (drilling a hole into the center and turning to break in out, came off easy as it was already broken into pieces). But when I tried the hole saw it just kept grabbing and I couldn't get it so cut in. So grabbed a butane torch, a spoon and a breathing mask and attacked it. Heated the spoon till red hot then just scooped it through the old bush, piece by piece! MAGIC! worked a charm, then got a little wire brush on the drill and cleaned up the insode no worries. After battling getting the new bush in, I got it all back together but still have my freakin clunk and backlash ahaha. At least I didn't waste $650 on getting someone to do it for me, and the bush needed to get done anyway. So now I am still chasing the backlash issue, next is to check diff, tailshaft (uni's) and gear box mount. the battle continues....(will post a few pics when I get the chance) Link to comment Share on other sites More sharing options...
Guest STEVE_BAXR Guests Posted 22/07/09 07:36 AM Share Posted 22/07/09 07:36 AM I just did my diff bush. it sounds bad BUT ITS THE EASY WAY 1 1/2 hours and the jobs done we cut hole's for intercooler pipe so.Just take the spare wheel out cut a nice hole with a eg air saw , get the old bush out put the new one in I can get them from www.superpropoly.com for under $100 .Then make a nice patch to cover the hole sikaflex and revert on then some paint all done ..PS next time you need to do it just take the patch off . Link to comment Share on other sites More sharing options...
seventytwo Still have a turbo, it's just on a diesel. Lifetime Members 5,368 Member For: 19y 7m 11d Gender: Male Location: The 8th Dimension Posted 22/07/09 12:10 PM Share Posted 22/07/09 12:10 PM Interesting Idea, how did you go about changing the diff bush through this hole. Link to comment Share on other sites More sharing options...
Guest STEVE_BAXR Guests Posted 22/07/09 07:45 PM Share Posted 22/07/09 07:45 PM (edited) Easy the hole was 12cm+12cm and for the bush I just got a hole saw to get the rubber out, then the air saw to cut a sice in the old metal outer of the bush air chisel it out, take care not to cut through the housing of the sub frame. There are varies techniques to get the bush .Paint both side of the the well then put the patch on so it will not rust......I only had black paint at home so black it was , you dont see it . Edited 22/07/09 07:55 PM by STEVE_BAXR Link to comment Share on other sites More sharing options...
sambo_xr6t Member 157 Member For: 15y 7m 3d Posted 10/08/10 12:14 PM Share Posted 10/08/10 12:14 PM any 1 in perth try and do this ? Link to comment Share on other sites More sharing options...
roy91tt Member 2 Member For: 14y 10m 5d Posted 01/09/10 11:16 PM Share Posted 01/09/10 11:16 PM Have just done the bush install.The new center nolathane bush slipped into the housing really easy. I also replaced the two smaller bushes with OEM ones at either side of the diff support arms. Should they just push in by hand easily? Or do they need to be pulled into position by the bolt?I am noticing a bit of driveline noise and getting a bit of a clunck when I acellarate fast/brake, as if the bush is allowing a bit of movement.Anyone had a similar issue? Link to comment Share on other sites More sharing options...
Brandon18 Member 54 Member For: 15y 30d Gender: Male Posted 01/02/11 09:59 AM Share Posted 01/02/11 09:59 AM Has anyone done a comparitive nolathane to superpro diff / driveline noise comparison test ? Link to comment Share on other sites More sharing options...
Mat_williams Member 2 Member For: 14y 3m 19d Posted 29/03/11 12:59 PM Share Posted 29/03/11 12:59 PM Hey guys im looking at doing the diff bushes to my '03 BA, Just wondering what brand of bushes are best. From what ive read the OEM ones seem to be best. Link to comment Share on other sites More sharing options...
