  • THE PSYCHO XRT
  • Member For: 19y 6m 8d
  • Gender: Not Telling
Hi guyz,
My car picked up some issues on a recent cruise and would like to share my recent experiements I tried with my car....
Problem(s)
Well, the car seems to be holding back on full boost (15-16psi) as if suffering from fuel starvation or something rather?? But then again, I do have the upgraded deka injectors and Walbro fuel pump so I dont think there should be an issue in this department?? It does not miss @ idle and it is otherwise smooth from the low to midrange.
The second issue I have which I picked up on the same cruise was that the car seems to take longer (about 3-4seconds) to crank over but this only occurs after the car has been sitting for a while, but when I go to crank it again after freshly turning the car off then it start straight away? Dont know if this makes sense but yeah that's the second issue I have with my car!
Diagnosing the car
Checked and cleaned all hoses/piping and electronic connector's. All were intact!
Did the boost solenoid maintenane
Replaced the spark plugs with the common NGK Iridiums BKR6EIX which are already gapped to .80mm
Replaced Coil's with my cousin's car
I did notice a difference after changing the plugs (ever so slightly) but the issue was still there so I exchanged coils with my cousin (XXRLNT) however the holdback was still there and I was like WTF!!!!!!!! :stirthepot:
Any help will be appreciated..
All in all, I do have the car booked @ Springy Performance first thing on Tuesday so I will let you guyz know what the promblem was....
Edited by Dagabond
https://www.fordxr6turbo.com/forum/topic/53859-car-holding-back-on-full-boost/
  • Replies 32
  • THE PSYCHO XRT
Ahhh yes, fark me! Why didnt I think of that!!
The shops are all closed now so ill have to wait till Tuesday!!
thanks heaps, will let you guyz know if this rectifies it or not. :stirthepot:
  • TEAM BA
  • Member For: 20y 6m 8d
it could also be the hose on the walbro pump has split, that's what happened to mine and the symptoms were very similar, it will still suck the fuel thrue but with a lot less preasure then normal
  • THE PSYCHO XRT
  ebxmple said:
Aha now your symptoms make sense San.Possible Fuel filter or even dicky fuel pump. Have you been getting your petrol from anywhere different?
I normally fill up from my local servo's and ALWAYS use the 98ron stuff....
I'll get springy to check that hose on the walbro pump aswell...
Thanks for the feebback guyz. :biggrin:
  • Here since the start...
  • Member For: 22y 1m 21d
Sounds fuel related to me.
Kind of like playing pin the tail on the donkey by the look of it. :roflmbo:
  • Member For: 18y 2m 12d
if youve got your car booked in to have professionals diagnose and fix the problem, why ask us?
  • THE PSYCHO XRT
Well, why not? Are we not allowed to share info on each other's pride and joy?
