balo New Member 12 Member For: 16y 5m 10d Gender: Male Posted 23/01/09 09:23 AM Share Posted 23/01/09 09:23 AM hey guys just wondering what thermostats use guys are using to run the car abit cooler 160 or 180 or whatever other ones thanks Link to comment Share on other sites More sharing options...
galapogos01 Donating Members 13 Member For: 17y 1m 3d Posted 24/01/09 08:19 AM Share Posted 24/01/09 08:19 AM you'll have to be careful with the car running richer if you run a cooler thermostat. Link to comment Share on other sites More sharing options...
typhoon_freak Cryptic Clothing Company Donating Members 4,556 Member For: 16y 6m 10d Gender: Male Location: Brisvages, Capalaba Posted 24/01/09 08:21 AM Share Posted 24/01/09 08:21 AM how does the car run richer with a thermo?? I use a 77deg thermo in mine.. most other people use 82deg Link to comment Share on other sites More sharing options...
P4N1C Member 26 Member For: 16y 11m 3d Gender: Male Location: Tullamarine, Melbourne Posted 05/03/09 09:48 AM Share Posted 05/03/09 09:48 AM how does the car run richer with a thermo?? I use a 77deg thermo in mine.. most other people use 82degThe PCM does an emissions test once the car reaches a certain temperature, if you run too cold of a termo (unless you tune has been modified) the factory configuration will never reach it emissions self test and they do run slightly richer.Factory thermo is around 190F, a 180-185F thermo will be more then sufficient. Link to comment Share on other sites More sharing options...
