Engine Rattle/tick Rhs
anthb86
  • Member For: 15y 9m 27d
just bought bf xr6t 78000ks. under acceleration there is a slight rattle/tick noise coming from the right hand side of the engine. ive heard it before in falcon taxi's ive been in. any ideas what it could be?
cheers.
  • It's not a MKI!
  • Member For: 16y 5m
could be a buggered rocker or lifter or even camshaft for that matter, it could also be an exhaust leak
Won't be a lifter. There aren't any.
I reckon there is a fair chance it might be an exhaust leak though.
If it's more pronounced under acceleration, it'd be worth checking all the exhaust/turbo gaskets and the dump pipe gaskets.
  • It's not a MKI!
Can you show me a picture of hydraulic lifters for the Barra engine as I've not seen them?
They have finger followers that run on the lash caps, but I didn't think there were any lifters involved.
  • Moar Powar Babeh
  • Member For: 19y 1m 27d
lifter/follower, we are pretty much splitting hairs now. They have hydraulic valve lash adjuster (HLVA's if you ask ford) They "follow" the cam and "lift" the rocker, oh and they adjust to maintan valve lash. They are very cute, about the size of a AA batter only 3/4's the length.
  • 2 weeks later...
  • blind leading the blind
  • Member For: 16y 2m 8d
I had the same problem couple times was a bolt holding dump pipe to turbo that come loose (actually fell out before I found it) if it is replace it with a hi tensile bolt cos ya wont get it tight again (believe me)
Matt
