Hank Scorpio Member 14 Member For: 16y 4m 2d Gender: Male Posted 14/01/09 11:31 AM Share Posted 14/01/09 11:31 AM mine started rattling once the centre muffler was removed Link to comment https://www.fordxr6turbo.com/forum/topic/53456-exhaust-has-developed-a-raspy-note/page/2/#findComment-802945 Share on other sites More sharing options...
EXR6T Member 224 Member For: 17y 7m 28d Gender: Male Location: Melbourne Posted 26/01/09 09:45 AM Share Posted 26/01/09 09:45 AM ive got the same problem.same setup, little bit less power.would this cause a loss in power?guess I'll replace the rear muffler when I replace the cat... Link to comment https://www.fordxr6turbo.com/forum/topic/53456-exhaust-has-developed-a-raspy-note/page/2/#findComment-810753 Share on other sites More sharing options...
louiseanddanny 10.5 @ 132MPH Donating Members 477 Member For: 17y 3m 20d Gender: Male Location: FALCON COUNTRY Posted 25/02/09 07:55 AM Share Posted 25/02/09 07:55 AM I thought id have a opinion on this I've had the center muffler removed and guess what same f##n sounds as you guys, been to get results from my experienced exhaust repairer ,maybe thinking I've got a leak or the rear muff is stuffed but repairer showed me that in general servicing manifolds ie; turbo and exhaust manifolds need to be checked and tightened. half my manifold bolts weren't tightened up and loosing boost as well now I'm pissed off that its been leaking for god knows how long. Check everything is done up tight it may be the cause as it was causing our exhaust buzz. Link to comment https://www.fordxr6turbo.com/forum/topic/53456-exhaust-has-developed-a-raspy-note/page/2/#findComment-830838 Share on other sites More sharing options...
Jake F6 Donating Members 327 Member For: 21y 10m 2d Location: Melbourne Posted 05/04/09 12:54 AM Author Share Posted 05/04/09 12:54 AM XRDOSE said: yeh I had the same problem after I had my centre muffler removed it turned out to be the rear muffler! replaced it and bobs your uncle problem fixed!Yep. I replaced the rear muffler with a stock one off a BF that I purchased from another member. Fixed the problem straight away, and its all good again.The note is so much better now!Cheers, Jake. Link to comment https://www.fordxr6turbo.com/forum/topic/53456-exhaust-has-developed-a-raspy-note/page/2/#findComment-855460 Share on other sites More sharing options...
coz Member 50 Member For: 16y 5m 17d Gender: Male Location: Brisbane Posted 12/04/09 07:38 AM Share Posted 12/04/09 07:38 AM louiseanddanny said: I thought id have a opinion on this I've had the center muffler removed and guess what same f##n sounds as you guys, been to get results from my experienced exhaust repairer ,maybe thinking I've got a leak or the rear muff is stuffed but repairer showed me that in general servicing manifolds ie; turbo and exhaust manifolds need to be checked and tightened. half my manifold bolts weren't tightened up and loosing boost as well now I'm pissed off that its been leaking for god knows how long. Check everything is done up tight it may be the cause as it was causing our exhaust buzz.exactly the same thing happened to me mate... I tightened them up, and they just came loose again after a few days, so I lock tightened them an I am hoping that has done the trick! Link to comment https://www.fordxr6turbo.com/forum/topic/53456-exhaust-has-developed-a-raspy-note/page/2/#findComment-859155 Share on other sites More sharing options...
