  • Member For: 21y 8m 30d
I took the car for a good long drive to Mt. Donnabuang, and gave it a bit of stick
going up themountain, which was fun.
Anyway, I noticed today that the exhaust has developed a "raspy" type
of note at certain revs (around 1800 RPM). It's only there for a small rev range.
Kind of sounds a bit like crappy Lancers with big exhaust, when they take off.
Could this be a cat converter on the way out? Any ideas? :msm:
  • Member For: 18y 2m 30d
Being factory muffer, I would say the baffles in side have come lose.
You will find the baffle plates are spot welded into place and with added exhaust
pressure on the rear muffler from deleteing centre and extra power would make the chances of
the plates coming lose.
  • NOT THERE!... THERE!
  • Member For: 16y 11m 22d
Try the heatshield first mate.
I'll be voting mine off the island when I get home tonight.
It's developed a shocking vibration in the last 2 weeks and it's started to happen not just at idle but at around 40k's as well. Worse when the AC is on.
Sounds like a f*cking rusty old corolla.
Worth a shot before you go replacing mufflers.
  • CNUTOX
  • Member For: 22y 3m 8d
I had the same problem. Put the centre muffler back in, and it went away. The factory rear muffler is really quite chinese. Probably made in the nizpro factory.
  • BIGRED
  • Member For: 18y 21d
yeh I had the same problem after I had my centre muffler removed it turned out to be the rear muffler! replaced it and bobs your uncle problem fixed!
