MICKAJ Member 245 Member For: 17y 4m 2d Posted 11/01/09 07:13 AM Share Posted 11/01/09 07:13 AM Hello all,Had the front bar off and re-sprayed, now the horn doesn't work properly. Sounds really muffled and farty and a little bit like a train.Had a look at how they are wired up, each horn has a blue wire going to each, and on the same loom there are two black wires tied back not connected to anything.Are the black wires meant to go anywhere?And what is the correct way they should be wired??Thanks Link to comment https://www.fordxr6turbo.com/forum/topic/53352-horn-sounds-shagged/ Share on other sites More sharing options...
MICKAJ Member 245 Member For: 17y 4m 2d Posted 11/01/09 08:08 AM Author Share Posted 11/01/09 08:08 AM All I need is someone to check their car and tell me how they are wired up, its just behind the grillTa!! Link to comment https://www.fordxr6turbo.com/forum/topic/53352-horn-sounds-shagged/#findComment-800470 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 2m 3d Gender: Male Location: Brisbane Posted 11/01/09 09:09 AM Share Posted 11/01/09 09:09 AM The loom goes to one horn, then the single black wire goes from the first horn to the second. I'm guessing your high tone horn is disconnected? Link to comment https://www.fordxr6turbo.com/forum/topic/53352-horn-sounds-shagged/#findComment-800516 Share on other sites More sharing options...
MICKAJ Member 245 Member For: 17y 4m 2d Posted 11/01/09 10:05 AM Author Share Posted 11/01/09 10:05 AM Well there is a main loom and then two small looms come out, each little loom has a black and a blue wire.The black wires feed back into the main loom?? Link to comment https://www.fordxr6turbo.com/forum/topic/53352-horn-sounds-shagged/#findComment-800564 Share on other sites More sharing options...
mic Donating Members 1,725 Member For: 17y 5m 10d Gender: Male Posted 11/01/09 10:09 AM Share Posted 11/01/09 10:09 AM no horn ? get a bullbar, lol. mine was playin funny games aswell, but after testing different combos it worked in the end. just swap em around mate until it works. Link to comment https://www.fordxr6turbo.com/forum/topic/53352-horn-sounds-shagged/#findComment-800568 Share on other sites More sharing options...
4CDXR6 Member 53 Member For: 17y 5m 7d Gender: Male Location: Dunedin, South Island, New Zealand Posted 11/01/09 09:47 PM Share Posted 11/01/09 09:47 PM I got the similar problem, horn sounds real weird, if you find out how its all ment to go post it up so I can check it out ta Link to comment https://www.fordxr6turbo.com/forum/topic/53352-horn-sounds-shagged/#findComment-800779 Share on other sites More sharing options...
ravenhard Donating Members 1,517 Member For: 17y 3m 25d Gender: Male Location: Blacktown! Posted 11/01/09 10:19 PM Share Posted 11/01/09 10:19 PM With my horn, from the loom there is one blue wire covered in a black sheath going to 1 horn. Then between the 2 horns that is a single black wire connecting them. If your horn sounds dodgy check the connections for the wires and also how the horn is bolted onto the body. If the bolt/nut is loose you get a bad earth meaning crap horn sound. Link to comment https://www.fordxr6turbo.com/forum/topic/53352-horn-sounds-shagged/#findComment-800791 Share on other sites More sharing options...
4CDXR6 Member 53 Member For: 17y 5m 7d Gender: Male Location: Dunedin, South Island, New Zealand Posted 11/01/09 11:04 PM Share Posted 11/01/09 11:04 PM sweet thanks! ... sometimes if you hold the horn on, it sounds like a Donkey! haha.. ehh ooorrr ehhh orrr Link to comment https://www.fordxr6turbo.com/forum/topic/53352-horn-sounds-shagged/#findComment-800811 Share on other sites More sharing options...
Trough Lolly Member 4,349 Member For: 20y 9m 19d Gender: Male Location: Mildura Posted 11/01/09 11:36 PM Share Posted 11/01/09 11:36 PM if the bumper was off for a respray they shouldnt have touched the horns theres no need to. Link to comment https://www.fordxr6turbo.com/forum/topic/53352-horn-sounds-shagged/#findComment-800826 Share on other sites More sharing options...
MICKAJ Member 245 Member For: 17y 4m 2d Posted 16/01/09 07:03 AM Author Share Posted 16/01/09 07:03 AM Problem solvedFYIIts all in the hips, or in this case all in the mounting bracket.Bracket was loose and the horrible noise was vibration being transmitted into the front bar. Link to comment https://www.fordxr6turbo.com/forum/topic/53352-horn-sounds-shagged/#findComment-804172 Share on other sites More sharing options...
