bluprinturbo Donating Members 605 Member For: 16y 11m 19d Gender: Male Location: brisbane Posted 01/02/09 05:25 AM Share Posted 01/02/09 05:25 AM (edited) PepeLePew said: Mate is the misfire consistently and easily repeatable? If so, buy ONE coilpack off EBay and play swapsies until you find the offender. If you dont find one, you have a new coilpack to add to the other 5 you will have to buy one day 10 seconds to change a pack with the lid offthis is what I did to.$44 for a coil from repco and after 5 swap and drives,problem solved.the car used to run ok at light throttle and then drop the cylinder higher up in the rev range.had to put the pipes and sh*t back on for each test,yeah, pita but only spent $44. Edited 01/02/09 05:27 AM by bluprinturbo Link to comment https://www.fordxr6turbo.com/forum/topic/53289-coilpack-question/page/4/#findComment-814492 Share on other sites More sharing options...
Superdan Well-Hard Bangin' Member Member 3,422 Member For: 17y 8m 10d Gender: Male Location: Perff, WA Posted 01/02/09 05:27 AM Share Posted 01/02/09 05:27 AM (edited) typhoon_freak said: umm no, cuz u probily wudnt be able to properly confirm with pack it is, without test driving, y dont u leave the cover off?yeh covers no dramas, just the stock piping's gonna be a pain. Fair enough though, just gotta do it!EDIT: on second thoughts, if the cars idling now and popping, then if I swap them out one by one until the popping stops... problem solvered right?? Edited 01/02/09 05:28 AM by Superdan Link to comment https://www.fordxr6turbo.com/forum/topic/53289-coilpack-question/page/4/#findComment-814493 Share on other sites More sharing options...
typhoon_freak Cryptic Clothing Company Donating Members 4,556 Member For: 16y 9m 20d Gender: Male Location: Brisvages, Capalaba Posted 01/02/09 05:38 AM Share Posted 01/02/09 05:38 AM good luck mate. Link to comment https://www.fordxr6turbo.com/forum/topic/53289-coilpack-question/page/4/#findComment-814498 Share on other sites More sharing options...
turbo.vixen Hey guys, Tab is here... Oh i feel sick Lifetime Members 8,459 Member For: 16y 11m 7d Gender: Male Location: sunshine coast Posted 04/02/09 10:34 PM Author Share Posted 04/02/09 10:34 PM ok so I bought 6 new coil packs, spark plugs and fuel filter and nothing has changed arrrggghhhh. iv booked into see my mechanic on monday to fix it cuz I give up lol, might be a leaking manifold? Link to comment https://www.fordxr6turbo.com/forum/topic/53289-coilpack-question/page/4/#findComment-817185 Share on other sites More sharing options...
turbo.vixen Hey guys, Tab is here... Oh i feel sick Lifetime Members 8,459 Member For: 16y 11m 7d Gender: Male Location: sunshine coast Posted 09/02/09 12:33 AM Author Share Posted 09/02/09 12:33 AM woohoo its all fixed, I had a dirty map sensor and metal fillings on the crank angle sensor which was throwing everything out of time. all cleaned, all fixed and running perfect. boost comes on nicely, no more popping, no more rough idle and now the power is alot stronger. so to everyone that has tried everything like me (plugs, coils, fuel filter, clean t/b, boost solenoid) have a look at your map and crank angle sensors Link to comment https://www.fordxr6turbo.com/forum/topic/53289-coilpack-question/page/4/#findComment-819395 Share on other sites More sharing options...
boosted_sa Member 270 Member For: 19y 9m 11d Posted 09/02/09 07:14 AM Share Posted 09/02/09 07:14 AM Just did my coil packs! DOH problem still there. Will do plugs now (they are only 30k old though)Where's the MAP sensor located on the manifold, did you have to check both CAS?Car still made 330rwkw on Sat (it was 41degC) very weird, little missing. Link to comment https://www.fordxr6turbo.com/forum/topic/53289-coilpack-question/page/4/#findComment-819632 Share on other sites More sharing options...
turbo.vixen Hey guys, Tab is here... Oh i feel sick Lifetime Members 8,459 Member For: 16y 11m 7d Gender: Male Location: sunshine coast Posted 09/02/09 07:26 AM Author Share Posted 09/02/09 07:26 AM the map sensor is under the t/body, and the c/a sensor was on the intake side of motor Link to comment https://www.fordxr6turbo.com/forum/topic/53289-coilpack-question/page/4/#findComment-819640 Share on other sites More sharing options...
