  • Replies 36
  • Cryptic Clothing Company
  • Member For: 16y 9m 7d
pretty sure u can get a voltmeter and to check the current that runs thruw them.. but swaping one over and going for a drive and then finding which one it is.. is prob a better way
  • Member For: 17y 1m 14d
this makes no sense at all. You can only use a voltmeter to check volts or a ampmeter to check current. You can use a multimeter to check both. You could get a multimeter to check the resistance and get a ohm reading but then any of these test wont tell you if the rubber insulation is breaking down.
  Quote
changing coils is alot of work. I was thinking of that to save money when I had a little issue but decided to change the lot. Got genuine ones off ebay for $200 delivered and changed the lot in 1 go. Fixed my issue.
that's it multimetere.. had a blonde momment and cudnt remember what it was so I put down voltmeter
  • 2 weeks later...
  • Member For: 17y 27d
As said above it wont do much good you can actually get a coil tester (the diesel fitters at my work use them, I am a sparkie) it can tell you if your coil is actually working (should gap about 12 mm). I guess if you wanted to test if the insulation is breaking down you will have to grab the coil pack with one hand and test the earth with the other, you will feel if it has got insulation break down (not recommended if you don’t like pain or have a sh*tty heart). Not even a normal insulation testing tool (MEGA) will be able to test if there is break down because they only go up to 1000V not the 48,000V that coils use.
Just change them all if you don’t want to waist to much time. Electrical tape won't do much either its not designed to take these sorts of voltages if you want to do it on the cheap see if you can find some resin filled heat shrink to heat onto it. I don’t know how much space you have down there in-between the cams.
If the car is doing while it is stationary (just being revved), Get someone to see if they can see any gapping while the cover is off (little thin blue spark), or again stick your hand down the side to feel it (again don’t jump up and smack your head on the bonnet or something like that hehe).
When I first got tuned and had a new cat it made lovely *BANG* noises on over run (doesn’t do it anymore :badmood: )
So anyway
Easy Fix: Replace them all
Hard Fix: Heat srink
Replace 1 at a time
  • Member For: 19y 8m 30d
Think my cars spark is breaking down in this hot weather, it sort of sounds like its missing when it comes onto boost under load. Haven't checked my plugs or coils yet. Does it sound like coil packs or plugs? also what gap for plugs?
Cheers, Kym
  • Hey guys, Tab is here... Oh i feel sick
  • Member For: 16y 10m 25d
  • Well-Hard Bangin' Member
  • Member For: 17y 7m 29d
I just got a single new one off ebay, just need to know, can you run the engine (idle) without any pipework on? I'm just thinking it's gonnabe a PITA to remove piping, swap one out, replace piping, test drive/run, cool down, repeat :spoton:
