20 X 10's On A Bf Phoon Anyone?
Guest
  • Replies 55
Posted Images
  • THE PSYCHO XRT
  • Member For: 19y 2m 23d
  • Gender: Not Telling
It looks fuggin awesome m8! Really TUFF looking! Chuck up a few more pics for a proper opinion but lookin at those ones really sets it off..... I like! :whistle:
  • Member For: 18y 9m 5d
looks good!my dads got the same on his bf typhoon 20x10s on the back with 275,guards were rolled and slightly pumped,his is bionic they suit most colours
cheers lee
Edited by dalts
  • Toughest BA Turbo
  • Member For: 22y 2m 6d
Rear offset is spot on.
Normally we fit a 275 on a 9.5" rear rim, rather than a 10".
I'd say that with many 275 tyres they are more likely to be skinny fit on the 10" rims, so you just have to be careful about scraping the rims.
Fitment depends on real width of rear tyres, as not all 275 tyres are a true 275mm width. I've had a 275 tyre that was more like a 245 when it was measured.
I put a 285 Pirelli on a 9.5" rim, and it didn't fit properly. It was measured, and was closer to 295mm in width.
It was then put on a 10" rim, and had major problems fitting under the guard, and as well as rolling the guard had to run 3 degrees negative camber to get it to fit.
20*10 do look very impressive!
Brian
  • Dropping a turd
  • Member For: 17y 4m 4d
The first 2 pics make it look really 'stuck out' but infact they are well in the guards.
As for a rim that sits further in, if I did that I'd scrub on something suspension related :crybaby: There's only about 5 - 8mm cleaance at the moment.
I worked it out once for a 19x9.5 with a 275 perfect offset was + 42. Just measured mine 19x8 rim +36, tyre comes to 240. Gap on the inside to the body is 32mm. Assuming your tyre comes to 275mm that's an extra 35mm more than mine. So the max go could comfortably put on the inside is 25mm leaving you a 7mm gap and the other 10mm you put towards the guard. Early FPV run +27 so that puts the tyre 9mm closer to the guard and that doesnt rub. So good offset is + 42. If you tyre is bigger that 275 and is closer to 285 you need to put most of that 10mm towards the guard so reduce the + offset by the extra width amount. You need to measure the actual size of the tyre on the rim as Brian is correct different tyres come to different sizes.
Do you realize 275/30/20 is 20mm in overall diameter bigger.
Try Big custom wheels website they have a tyre rim calculator.
