Kroozin Menace Donating Members 1,990 Member For: 14y 1m 16d Gender: Male Location: Sydney Posted 25/06/13 11:02 AM Share Posted 25/06/13 11:02 AM Thanks to misk_one from fordmods. Copied and pasted just read this randomly lol. BA-BF before june 06 NA and turbo have the same rods with full floating gudgeon pin. E-gas motors use a stronger conrod (ie. F6 style) with press fit gudgeon pin. the weaker style conrod is the same as used in AU engines excepted for the floating gudgeon pin. BF june 06 - FG, NA engines retain the older style conrods still with full floating gudgeon pin. Turbo and E-gas use the same style and strength rod (again, F6 style) but still retain the pin style specific to the engine (ie. Gas - press fit, Turbo - full floating). All pistons used are the same strength and basic make up; the differences being press fit pin and very high compression for E-gas engines, full floating gudgeon pin and normal compression for NA engines and full floating gudgeon pin with 8:7.1 comp for the turbo pistons. these can all be used in an AU block with an AU crank for some very cheap combos if you are smart about it. would be fantastic to use some E-gas pistons and rods in a high comp huge cam NA engine, or a high comp mild power turbo setup with the NA pistons, while the Turbo pistons are good for 400-420rwkw. the pistons do need to be checked for clearance and flycut for the intake valve if required though. the stronger rods are all good for around or even above 450rwkw. Link to comment https://www.fordxr6turbo.com/forum/topic/53187-help-with-short-motors/page/3/#findComment-1401390 Share on other sites More sharing options...
