JP300 Donating Members 842 Member For: 19y 5m 26d Gender: Male Location: Sydney Posted 07/01/09 11:06 AM Share Posted 07/01/09 11:06 AM was that with a stock turb ?I believe that it was a stock Turbo with an upgraded wastegate actuator. Link to comment Share on other sites More sharing options...
Tocchi Sandtrap Motorsport Donating Members 2,055 Member For: 16y 3m 14d Gender: Male Location: Perth Posted 07/01/09 11:21 AM Share Posted 07/01/09 11:21 AM how much is the nitto? Link to comment Share on other sites More sharing options...
mic Donating Members 1,725 Member For: 17y 1m 21d Gender: Male Posted 07/01/09 11:23 AM Share Posted 07/01/09 11:23 AM I believe that it was a stock Turbo with an upgraded wastegate actuator.must have been that ute ..... if the nitto sits closer 2 the intake, then in theory it should be less laggy ???? Link to comment Share on other sites More sharing options...
Tocchi Sandtrap Motorsport Donating Members 2,055 Member For: 16y 3m 14d Gender: Male Location: Perth Posted 07/01/09 11:42 AM Share Posted 07/01/09 11:42 AM no, more laggy.the longer runners promote low down torque, and since the Nitto has short runners, its top end specialityits how the BBM (on NA cars) worksbelow 3500rpm the short runners are blocked off, so the long runners are used, promoting low down torqueonce it gets to 3500rpm, the butterflys open and the short runners are used Link to comment Share on other sites More sharing options...
Guest Guests Posted 07/01/09 11:41 PM Share Posted 07/01/09 11:41 PM The Nitto plenums are also rather large in terms of volume when compared to others, hence the greater top end. That would also contribute to the sloppy low end torque I'd say Link to comment Share on other sites More sharing options...
RIPGMH Donating Members 302 Member For: 20y 8m 3d Gender: Male Location: Sydney Posted 08/01/09 06:33 AM Share Posted 08/01/09 06:33 AM I have been a passenger in a 10 second nitto fitted xr ,there was no evidence of any flat low down spots.This car wheel spun 1/4 of track on full slicks yet still run 10s,this plenum works Period ! Link to comment Share on other sites More sharing options...
mic Donating Members 1,725 Member For: 17y 1m 21d Gender: Male Posted 08/01/09 06:44 AM Share Posted 08/01/09 06:44 AM I think it would be a great piece. was this car using a stock turbo mate or a larger 1 ? Link to comment Share on other sites More sharing options...
JP300 Donating Members 842 Member For: 19y 5m 26d Gender: Male Location: Sydney Posted 08/01/09 08:22 AM Share Posted 08/01/09 08:22 AM I have been a passenger in a 10 second nitto fitted xr ,there was no evidence of any flat low down spots.This car wheel spun 1/4 of track on full slicks yet still run 10s,this plenum works Period !I agree, it is a great plenum if you want to build a quick drag racer when you are operating at the high end of the rev range 95% of the time under high load... but it does not help low to mid range torque hence drivability which is what most of the cars are used for (based on what I have seen and heard).I guess it comes down to what the buyer wants to achieve ... Link to comment Share on other sites More sharing options...
RIPGMH Donating Members 302 Member For: 20y 8m 3d Gender: Male Location: Sydney Posted 08/01/09 10:17 AM Share Posted 08/01/09 10:17 AM Vehicles such as ours are now comunly tuned in excess of 300 rwkw,regardless of throtle position and plenum size, there is more than ample torque to move vehicle effortlessly.thanks to a generous displacement 4 litre engine.suggesting this set up is more suited to racetrack and or higher revs is not being realistic.as far as drivability is concerned it is no different to any other t.All Turbo Falcons drive like naturally aspirated falcons,(UNTILL) they spool up,only then does the turbo generate enough gas to feed air to intercooler,plenum and throtle body .My opinion is :if a n/a Falcon engine is the leader in its class Torque monster,having a Turbo/larger Plennum added to it ,doesnt mean you need to rev it highly or have a high load . Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 10m 13d Gender: Male Location: Victoria Posted 08/01/09 07:52 PM Share Posted 08/01/09 07:52 PM Aren't they $3.5k?I'd say the Nizpro, Process West, Plazmaman etc etc units would be money better spent. Link to comment Share on other sites More sharing options...
