Air Inlet
  • Member For: 21y 5m 19d
I noticed the air inlet to the airbox :thumbsup: has a bigger opening on the XR6 turbo comp[ared to the XR6 non turbo. If this larger inlet was fitted to a non turbo XR6 would there be a slight increase in power because of more airflow?
  • Member For: 21y 6m 16d
I got an AU2 xr8 snorkel on my N/A xr6 which I think is the same size of the xr6 turbo snorkel. I cant personally notice any difference but I reckon its still better than that small stock one :)
and the xr8 AU2 one has a nice tickford sign on it lol
  • TEAM BLUEPRINT
  • Member For: 21y 11m 23d
faygun
did you have problems fitting the au snorkle to thba xr6t.
I tried to fit my au tickford snorkle of auxr8 and it would not fit my baxr6t.
  • Member For: 22y 1d
I noticed the air inlet to the airbox <_< has a bigger opening on the XR6 turbo comp[ared to the XR6 non turbo. If this larger inlet was fitted to a non turbo XR6 would there be a slight increase in power because of more airflow?
You wont notice any additional power with the snorkel on it's own, but it does look a bit better with the larger snorkel.
1axr> No, it was pretty straight forward. The only thing was that the small hose coming off the radiator was touching the snorkel when I changed it so I just pulled it a bit from the radiator side and it was all okay. Im not sure if the AUxr8 and AU2xr8 snorkels are the same. But they are all very similar anyway. You just got to make sure when you are putting the new snorkel to the air box, make sure it clicks in. There is actually a good link on this mod if you want to check it out.
http://forums.fordmods.com/phpBB2/documents.php?doc=16
  • TEAM BLUEPRINT
faygun
just to let you know I fitted the au snorkle and it went on like a dream. don't know what I was doing when I tried to fit it last time.
my snorkle is actually of a au t series and has been cut back at the top to let more air in.
your question on the panel filters. you may get a slight induction noise but I don't think it would be that great.
sid
