Stock Xr6 Turbo Dump Pipe
boost_lover
Pretty sure he had aftermarket dump, cat, exhaust etc :crybaby:
You might as well go aftermarket seeing as you'll have to buy a stocker anyways. Bigger dump helps to spool quicker & reduces back pressure on valve springs which would be of benifit to your NA head I'd amagine :beerchug:
  • Member For: 16y 4m 7d
Pretty sure he had aftermarket dump, cat, exhaust etc :spoton:
You might as well go aftermarket seeing as you'll have to buy a stocker anyways. Bigger dump helps to spool quicker & reduces back pressure on valve springs which would be of benifit to your NA head I'd amagine :spoton:
well the stock na valve springs will suffer the same fate as stock turbo valve springs. I have been offered stronger valve springs.
  • Member For: 17y 1m 5d
I have a 3" dump pipe on mine, its the APS 3" but its pretty much identical to the stocker though if that helps,
bigger dump pipe means bigger numbers up the top of the rev range in more extreme power ranges
