J3TXR6 Member 88 Member For: 16y 5m 13d Gender: Male Location: Melbourne Posted 05/01/09 02:39 AM Share Posted 05/01/09 02:39 AM Hi all,I have an XR6t. I just installed my sub and amp into the car and it sounds mand....However I've connected the trigger wire to the 21v wire which is the automatic headlight feature. Now I dont want to pull my ICC out so I was wondering if there is another place I can re-wire my trigger wire so another spot so it can work when the car is in accessories mode. cheers Link to comment Share on other sites More sharing options...
tjb45 New Member 14 Member For: 18y 11m 8d Posted 05/01/09 03:54 AM Share Posted 05/01/09 03:54 AM You can use a wire in the drivers side fuse box.Its the second one from the top on the right hand side (Small blue wire) Link to comment Share on other sites More sharing options...
Taxi 8 u Member 57 Member For: 16y 6m 27d Gender: Male Location: Where you want to be! Posted 05/01/09 07:16 AM Share Posted 05/01/09 07:16 AM Or you could just get an Acc trigger from the 4 pin plug used to power phone car kits! Link to comment Share on other sites More sharing options...
sicklaser Member 183 Member For: 18y 4m 17d Location: Mackay QLD Posted 05/01/09 08:50 AM Share Posted 05/01/09 08:50 AM or pinch it from the cigarette lighter. the phone plug would be the best spot but Link to comment Share on other sites More sharing options...
kodaz Member 28 Member For: 16y 1m 20d Gender: Male Location: Brisbane Posted 07/01/09 05:54 AM Share Posted 07/01/09 05:54 AM Anywhere in the boot to do this? Link to comment Share on other sites More sharing options...
sicklaser Member 183 Member For: 18y 4m 17d Location: Mackay QLD Posted 07/01/09 07:53 AM Share Posted 07/01/09 07:53 AM nope Link to comment Share on other sites More sharing options...
XR06T Silver Donating Members 4,146 Member For: 19y 7m 3d Gender: Male Posted 07/01/09 08:01 AM Share Posted 07/01/09 08:01 AM I used the cigarette lighter for mine, but the mobile phone plug is the best option.look for a topic I started on hardwiring radar detectors for which slot you will need. Link to comment Share on other sites More sharing options...
J3TXR6 Member 88 Member For: 16y 5m 13d Gender: Male Location: Melbourne Posted 08/01/09 01:01 AM Author Share Posted 08/01/09 01:01 AM I tried searching for the cigi lighter wire but there was just too much stuffing around to get to it...(didnt have much time to do the install) I found the blue wire with the white line so I'm gunna try and use that one instead of the auto-light feature wire. if your car had premium sound you might be able to find a trigger wire spot of the stock amp. I'm pretty sure theres one. Link to comment Share on other sites More sharing options...
sicklaser Member 183 Member For: 18y 4m 17d Location: Mackay QLD Posted 08/01/09 08:02 AM Share Posted 08/01/09 08:02 AM no the can-bus turns the factory amp on Link to comment Share on other sites More sharing options...
