Guest Guests Posted 12/01/09 09:07 AM Share Posted 12/01/09 09:07 AM Race Brakes sydney say bracket's cannot be purchased seperately.... Best I be hunting down the importer...The importer wont sell them without brackets either, or sell you just brackets. Do you have the calipers already or looking at buying a set, why not just buy a set that alread has the BF bracket's. Link to comment Share on other sites More sharing options...
RDCULS New Member 16 Member For: 17y 5m 13d Posted 14/01/09 08:15 AM Share Posted 14/01/09 08:15 AM OK then, was thinking about going for the full set on flea-bay (to suit FG) & swaping brackets... Think I will abandon that idea now...Cheers Link to comment Share on other sites More sharing options...
Guest Guests Posted 14/01/09 10:04 AM Share Posted 14/01/09 10:04 AM OK then, was thinking about going for the full set on flea-bay (to suit FG) & swaping brackets... Think I will abandon that idea now...CheersJust buy some that suit a BA-BF, there's plenty floating around. Link to comment Share on other sites More sharing options...
micksta Member 159 Member For: 20y 3m 11d Gender: Male Location: NSW Posted 19/01/09 10:59 AM Author Share Posted 19/01/09 10:59 AM The brackets cant be purhased seperate from anyone. As for the rubbish about the calipers not fitting a F6 that's rubbish, they are all the same and share the same part numbers. You can order a F6 with the 6/4 combo.....The brake booster from the base model to the F6/GT-P will support the brembos as it has done in all previous models.Lastly the front 4 pot fronts WILL NOT fit the rears, the brackets are totaly different and the front discs are 355x32mm while the rears are 330x26mm.Spot on, that’s correct the fronts callipers wont fit the rears, they are a different type of calliper.The 6 pot callipers fitted the fronts with no issue. Link to comment Share on other sites More sharing options...
