Dagabond Bored Member Administrator 35,722 Member For: 22y 5m 26d Gender: Male Location: Dé·jà vu Posted 01/01/09 01:01 AM Share Posted 01/01/09 01:01 AM The hole where the amp goes in the boot... Link to comment https://www.fordxr6turbo.com/forum/topic/52943-factory-amp/page/2/#findComment-794152 Share on other sites More sharing options...
XRSics Donating Members 325 Member For: 16y 7m 4d Gender: Male Location: Melbourne Posted 01/01/09 01:18 AM Share Posted 01/01/09 01:18 AM top left side of boot (in premium models) dunnobout standardif fitting one from normal sound package, id just locate it somewhere elseand get as big as u need Link to comment https://www.fordxr6turbo.com/forum/topic/52943-factory-amp/page/2/#findComment-794156 Share on other sites More sharing options...
smicky Go Pies!!! Donating Members 2,852 Member For: 17y 2m 23d Gender: Male Location: Vic Somewhere - Sometimes NSW Posted 01/01/09 05:42 AM Share Posted 01/01/09 05:42 AM (edited) There is plenty of room in the boot housing (hole as dags referred to) to fit a larger amp if needed.Some support rails may need to be cut and fitted, however not a hard thing to do at all!If your not sure, best to get your local car audio shop to give you hand I would think mate.If you have Premo sound the amp is located behind the 'boot lining' where the others have mentioned... Edited 01/01/09 05:44 AM by smicky Link to comment https://www.fordxr6turbo.com/forum/topic/52943-factory-amp/page/2/#findComment-794233 Share on other sites More sharing options...
kodaz Member 28 Member For: 16y 5m 4d Gender: Male Location: Brisbane Posted 02/01/09 09:57 PM Share Posted 02/01/09 09:57 PM Is it the same place in an FG G6ET? Link to comment https://www.fordxr6turbo.com/forum/topic/52943-factory-amp/page/2/#findComment-794890 Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 10m 21d Gender: Male Location: Earth Posted 02/01/09 10:43 PM Share Posted 02/01/09 10:43 PM All FG sedans with premium sound have the amp mounted in the l/h side of the boot behind the trim panel.So yes, kodaz, it is there. Link to comment https://www.fordxr6turbo.com/forum/topic/52943-factory-amp/page/2/#findComment-794908 Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 11m 14d Gender: Male Location: Melbourne Posted 02/01/09 10:58 PM Share Posted 02/01/09 10:58 PM Dude don't bother, I almost went down that road. You won't find a big enough good enough multi channel amp that fits where the factory one goes.Sure you could get a small mono to run just the sub but then the rear speakers will crack the sh*ts and probably tell to stick the whole thing up your Hope that helps a bit. Link to comment https://www.fordxr6turbo.com/forum/topic/52943-factory-amp/page/2/#findComment-794914 Share on other sites More sharing options...
kodaz Member 28 Member For: 16y 5m 4d Gender: Male Location: Brisbane Posted 03/01/09 04:05 AM Share Posted 03/01/09 04:05 AM PHANTMXR6 said: All FG sedans with premium sound have the amp mounted in the l/h side of the boot behind the trim panel.So yes, kodaz, it is there.Thanks, will certianly make wiring the audiocontrol lc6 much easier. Link to comment https://www.fordxr6turbo.com/forum/topic/52943-factory-amp/page/2/#findComment-795155 Share on other sites More sharing options...
B-1B Member 9 Member For: 18y 1m 11d Posted 03/01/09 09:22 AM Share Posted 03/01/09 09:22 AM kodaz, that is the spot where I mounted my LC6.I mounted the both amps on the sub box. Link to comment https://www.fordxr6turbo.com/forum/topic/52943-factory-amp/page/2/#findComment-795301 Share on other sites More sharing options...
bentles Member 121 Member For: 16y 7m 11d Gender: Male Location: melbourne Posted 03/01/09 10:34 AM Author Share Posted 03/01/09 10:34 AM Dillz said: Dude don't bother, I almost went down that road. You won't find a big enough good enough multi channel amp that fits where the factory one goes.Sure you could get a small mono to run just the sub but then the rear speakers will crack the sh*ts and probably tell to stick the whole thing up your Hope that helps a bit.yeah I got a 4 channel for speakers already but I dont want to take more space up. and want it to still look stockish.so was just going to get a small mono or 2 chanel for sub. Link to comment https://www.fordxr6turbo.com/forum/topic/52943-factory-amp/page/2/#findComment-795323 Share on other sites More sharing options...
kodaz Member 28 Member For: 16y 5m 4d Gender: Male Location: Brisbane Posted 07/01/09 06:09 AM Share Posted 07/01/09 06:09 AM B-1B said: kodaz, that is the spot where I mounted my LC6.I mounted the both amps on the sub box.Cool, it's always nice to have someone who went before you. Can you tell me where you got your ACC wire from and whether you used the standard speaker cabling (thinking of keeping it to avoide too much interior dismantling). Link to comment https://www.fordxr6turbo.com/forum/topic/52943-factory-amp/page/2/#findComment-797988 Share on other sites More sharing options...
