102 Mm Straight Through System
Sleeper6T
  • Member For: 17y 17d
Well, nizpro have now fitted 6 or more systems and another 6 at other dealerships. is there anybody out there to give some feedback?
my system is now fitted but is going back to sort out some clearance and noise problems but I haven't seen or heard it yet.
if there is anyone out there with it fitted could you whack up a sound clip?
  • Replies 171
Posted Images
Well, with my system on, it has proven almost impossible to get the car to run under 16psi. The quality if the system itself is described as 'second to none'. However, it sounds as if it is best suited to applications running higher boost and power levels. Still plugging away with it. Hopefully, for a good result!
You are correct, nearly no back pressure - it's so high flowing 'it's ridiculous'. Would this make life easier on the valve springs?
I thought that it was more like 32mm...can anyone confirm?
  • 2 weeks later...
