2007 Bf Mkii Xr6
Jake27
  • Replies 63
  • Member For: 17y 1d
Under drive pulley systems increase engine horsepower by reducing the amount of power required to drive external engine accessories. For example, the alternator, power steering, water pump and air-conditioning compressor rob horsepower from the engine. By replacing factory-sized crank and accessory drive pulleys with a resized pulley, the accessories are slowed, resulting in more horsepower available to the drive wheels. Typically, a set of pulleys from B.P.T. will increase power by 9 - 11kW's, and increase mileage. All pulleys are manufactured from Billet steel and aluminum, exceeding factory quality. All pulleys sets are fully neutral balanced at the factory.
  • Member For: 16y 5m 11d
oh, thank you. I think I understand.
Does that not just labour the other bits then running with less power?? ie if the water pump is running slower then it would have to pump less water.. yes?? would the power steering / ac stuff out quicker having to do the same job with less power??
or am I way off??
prolly shuda started a new topic instead of hijacking this one... :snf (51):
Edited by XRSics
  • Member For: 16y 10m
XRSics,
I have installed the under pulley on my BF XR6 NA and I have to say it works really well. I noticed the difference as soon as it was installed. I can safely say that all other components like AC and power steering run perfect and you will notice no difference in the way the perform. Basically because the pulley is lighter and smaller than the factory one the engine needs to use less of its power to run those accessories. This means that it can then conserve it for extra performance and econonmy. Basically you are not making any "extra power" from what you already have, but you are just redirecting it into useable kws by not handing them oer to you A/C etc. that's where you see the extra 9rwkws on paper.
For the price of the item it is a bargain given that I paid around $2500 for a stainless steel herrod exhuast which gave be roughly 15rwkw give or take. I would definately reccomend the product to anyone.
  • Member For: 16y 6m 13d
The K&N Filter and the chrome mesh grill are now in/on the car :)
Still waiting for delivery of the PH4490, SS inductions CAI and GT rear wing.
I put my order in for a 2.5" stainless steel system and a high flow cat.
The exhaust place was adamant that the O2 sensor would not be a problem so hopefully he's right...
Edited by Jake27
  • Member For: 16y 9m 5d
Its looking good Jake!!
Btw, when you get your GT wing done, would you mind posting how much it cost you to get it primmed/painted? or are you buying one that's already your colour?
Thanx mate,
Vebbers
Thanks Vebbers :)
I received the GT wing today which cost me $250 off eBay, it's quite a nice copy too :)
I took it to Spraypaint Perfection in Port Macquarie and it's going to cost $200 to have it painted in Ego.
It's already primed too.
Plus the painter stole my petrol hatch for the week so if anyone needs to siphon some petrol late at night, I'll give you my address.
The GT wing should be finished by Friday or Monday hopefully :)
My 2.5" X-Force catback system was fitted an hour ago :D
I'm very happy with the sound, the guy took back what he said about the high flow cat working too now that he's had a look under it :P
The extractors are taking forever to arrive too so I'll have to get it back into the shop to get those in.. ordered them 21st Dec which is annoying.
The car feels a bit different but since it's pouring down rain here I can't put the power down to the road, but the sound is great :)
The catback x-force system was $650 supplied and fitted.
Once I've got the extractors, he's planning on customising something similiar to a cat that won't effect the two o2 sensors... I wasn't paying enough attention to what he was saying because I was too excited to start it up to have a listen :P
Now I've just got the ph4490 and SS inductions CAI to fit as far as engine work goes before I get a custom tune :)
The GT wing will be dry enough to fit tomorrow too which should look great on it :)
  • Member For: 16y 9m 20d
Quick question(s) about the exhaust
I have a BF also and was thinking of putting an Xr6t exhaust on it.
If I buy a complete Xr6t exhaust does it retain my factory cat? Will the car go in LIMP mode if I put an Xr6t exhaust on it?
How much $$$ is normally involved in fitting an Xr6t exhaust?
Does anyone have any audio of what it sounds like on a n/a Xr6??
Cheers
