  • Member For: 17y 3m 12d
there seems to be a opinion that if your cars a BA you must do your valve springs first before you do any mods which I find kinda funny. The springs can start have trouble anywhere from stock to 350rwkws depending on other mods. Do your mods first and get a tune, if you have trouble with the springs then get it changed. Valve float can be easily seen in a Dyno graph.
  • Replies 32
  • Member For: 17y 5m 27d
yeah from what I have been reading what u say is wht im hearing. im kinda led to believe that its a case of if it aint broke dont touch it.
this is why I said mybe to the spring cause I thought id wait and see.
  • Member For: 17y 3m 21d
I have an 04 ba and put a rapid v2 kit on and did injectors and gutted the cat and she made 301rwkw @ 12psi. I think it really depends on your car :badabing:
  • Mmmmm......BOOST
  • Member For: 18y 1m 18d
most reputable shops will be close as far as dyno readings go ,mines been on 3 different dyno's an run between 305 and 312rwkw
and my stock valve springs are holding but only just they really need doing, if it is a sedan you might be better getting a surge tank and second fuel pump ,other than that mines got 60lb seimens ,process west stg 1 cooler with ubp ,high flow cat ,process west surge tank and bosch 044 ,k&n and 2nd air intake
and yes 300rwkw killed my auto
  • Legendary member!!
  • Member For: 18y 4m 24d
In relation to valve springs, it is gonna be impacted by your choice of exhaust mods.
Iv been told that if you have a good free flowing dump/cat or preferably full exhaust, your valve springs are going to have less backpressure on them as a result of that are less likely to see valve float (although it can still happen).
I have the stock BF 1 springs in mine and they are going fine. I have a full 4 " system though.
I dare say that if I was only running the stock dump with just a cat that I would probably be having some valve float problems at my power levels.
I have some Nizpro springs at the ready if I need them but im probably gonna be ok with the exhaust as it is...
