  • Replies 61
  • Member For: 19y 1m 7d
  XRSCAR said:
Dillz its not true, I have a tomato looking face and brown arms after Sunday!
Anybody use steam on here?
my account is: scar96
I have steam. my user id is tugger.
  • Member For: 17y 6m 7d
  smicky said:
Mate - havent got a PS3 however this sounds like a network issue... obviously!!! (your prob thinking - no sh*t!)
But - r u running your connection (ADSL im assuming) via a router or directly from the modem to the PS3?
Its 'sounds' like it could be a setting issue in the router settings... Ie- firewall, or DMZ/Port settings...
Let me know how you have this setup and see if I can help u trouble shoot it!
:stupid:
Thanks Smicky, Nah I haven't got a router, I just unplug the pc from the standard optus 'motorola' modem, unplug the mogem power for a minute or 2, plug in the ps3 and turn the power on for both the ps3 and modem. It really is driving me insane as sometimes it works no worries, most times it doesn't work and VERY occasionally if I leave the ps3 hooked up for a few hours it will work eventually.
have been advised to try a router but don't know whether that will fix my problem or not. don't really want to buy one to find out it was a waste of money.
  • Bored Member
  • Administrator
  • Member For: 22y 5m 18d
  ZAP_F6 said:
P.S Smicky a Nerd is a bookmonkey like a scientist or researcher a GEEK is a techie like a computer person, etc.
...and a Dork is the one who can tell the difference between the two.. :stupid:
  • Member For: 17y 11m 6d
  Dagabond said:
...and a Dork is the one who can tell the difference between the two.. :thumbsup:
Lol, Zap own.....Nice.
  • Go Pies!!!
  • Member For: 17y 2m 15d
aaahhhh - sounds like it might be an IP addressing issue...
Does the modem have a model number on it somewhere? (Sticker on the bottom?)
Is the modem a USB based connection or cat5? Assuming its cat 5, there should be a setting within the modem where is has reference to IP or DHCP client numbers, (basically this means the number of computers that can be given access to the modem at the same time)...
What may be happening is when you have the modem connected to the puter, then unplug and connect to the PS3, the modem is not refreshing the connection and therefore still thinks its connected to the pc... (easier way to explain it if that makes sense)...
By turning the devices off it is power cycling and reissuing the addresses.
The reason it also works when it is connected for a longer time - is the modem will have an expire time set where the connection between the device will be refreshed as well...
:stirthepot:
Let me know what the modem model is and ill see what I can find...
1. Nerd as I will be researching the info.
2. geek as I will be helping out with electronic stuff...
3. Dork??? not to sure on that one!
:spit:
BTW- see your in Sydney, we have a spare test router here in Sydney which I might be able to get out to you to borrow to see if it helps, this way you dont have to buy anything until you know it works... :argue:
Edited by smicky
  • Go Pies!!!
  IEATV8S said:
Anyone use LAN centres anymore????
uuuummmm aaahhhh
