xr6tinscotland Member 10 Member For: 16y 4m 28d Gender: Male Location: Scotland, U.K Posted 09/12/08 09:38 AM Share Posted 09/12/08 09:38 AM How much power can you get out the BA mk2 engine before you should look at changing or upgrading the internals?I have plazmaman XR6 Ford Intercooler kit - Stage 1 , can this be repiped to allow me to put the air induction straight onto the turbo , what options can I do with this kit without having to buy all new parts?If I do make changes will the engine tune I have need retuned as no one over here worked with xr6t falcons before as ive been told that the throttle responce is much better. Link to comment https://www.fordxr6turbo.com/forum/topic/52357-how-much-power-before-changing-internals/ Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 2m 27d Gender: Male Location: SW Sydney Posted 09/12/08 10:42 AM Share Posted 09/12/08 10:42 AM Generally the max for BA motors is the low 300rwkws. Some have gone higher but its really like playing with fire..The kit you have is really only designed to directly replace the standard piping, so customising it would probably be just as expensive as getting a RAPID kit sent over there!Do some research in the sub orums about the various intake kits that are available and you should get an idea to what you need.If you leave the exhaust the same and only change the intaek, your tune should be fine. Link to comment https://www.fordxr6turbo.com/forum/topic/52357-how-much-power-before-changing-internals/#findComment-783540 Share on other sites More sharing options...
Erko Donating Members 1,079 Member For: 21y 7m 2d Gender: Male Location: Sydney Posted 09/12/08 10:45 AM Share Posted 09/12/08 10:45 AM (edited) what sort of power are you chasing? 500bhp should be pretty straight forward and give you a lot of bragging rights with the local 4 cylinder boys!On pipe routing and airbox options I would speak with RAPID (Chris) from Rapidsystems who are a sponsor and have their own subforum. That Plazmaman core should flow 350rwkw no problems. Re ECU tuning, if you are chasing power then most certainly yes you will need something done there. I know there are tuners in the UK who tune the Vauxhaul Monaro and most likely use a Flash tuner....the same set up can be used on the Ford. There are also some other piggy back options that could be used in a pinch. I am sure a decent solution can be found for you. Injectors,Surge tank and fuel pump with connections can be sourced from OZ easily.....likewise an off the shelf X Force exhaust system, Clutch, Valve springs etc. I'd imagine a modified XR6T would blow some minds over there......especially spooling up on high street!! Edited 09/12/08 10:46 AM by Erko Link to comment https://www.fordxr6turbo.com/forum/topic/52357-how-much-power-before-changing-internals/#findComment-783543 Share on other sites More sharing options...
davidald Me Donating Members 360 Member For: 18y 1m 6d Gender: Male Location: Adelaide Posted 09/12/08 11:03 AM Share Posted 09/12/08 11:03 AM Off topic sorry, how did u get an XR6T in Scotland? Link to comment https://www.fordxr6turbo.com/forum/topic/52357-how-much-power-before-changing-internals/#findComment-783562 Share on other sites More sharing options...
SubJimbo ŠύЂפֿĺmβø ™ Donating Members 1,216 Member For: 17y 4m 2d Gender: Male Location: Melbourne Posted 09/12/08 11:04 AM Share Posted 09/12/08 11:04 AM Link to comment https://www.fordxr6turbo.com/forum/topic/52357-how-much-power-before-changing-internals/#findComment-783563 Share on other sites More sharing options...
xr0500 Donating Members 321 Member For: 19y 4m 2d Gender: Male Location: Hobart, TAS Posted 09/12/08 11:05 AM Share Posted 09/12/08 11:05 AM (edited) Sorry to hijack, but I have to ask (it has probably been asked before, two minutes ago HAHA)But how/why is there an xr6T in Scotland?????Oh and to remain slightly on topic im with Senna and Erko, check out Rapids gear, good stuff and from what ive heard easy to install which is a bonus Edited 09/12/08 11:06 AM by xr0500 Link to comment https://www.fordxr6turbo.com/forum/topic/52357-how-much-power-before-changing-internals/#findComment-783566 Share on other sites More sharing options...
Chich Damn You's A Sexy Chich Member 3,843 Member For: 17y 2m 18d Gender: Male Location: Your House Posted 09/12/08 11:12 AM Share Posted 09/12/08 11:12 AM (edited) this has me intrigued also... what made you want an xr6t in scotland and did you import it yourself...???Also do you take the high road or the low road...??? Edited 09/12/08 11:15 AM by onboost Link to comment https://www.fordxr6turbo.com/forum/topic/52357-how-much-power-before-changing-internals/#findComment-783572 Share on other sites More sharing options...
BFHOON Donating Members 1,932 Member For: 19y 1m 10d Gender: Male Location: nsw Posted 09/12/08 11:17 AM Share Posted 09/12/08 11:17 AM that kit you have there if it has the around the battery pipe fitted with a good exhaust system and injectors will make 320 rwkw easy, its a very high flowing cooler. (I have done it.)if you turn the pipe around it will perform better, but as said above mabee a rapid kit could be shipped to you with all the parts needed to make bulk horespower. Link to comment https://www.fordxr6turbo.com/forum/topic/52357-how-much-power-before-changing-internals/#findComment-783574 Share on other sites More sharing options...
MRDOSE Member 1,195 Member For: 17y 4m 5d Gender: Male Location: Sydney Posted 09/12/08 11:19 AM Share Posted 09/12/08 11:19 AM onboost said: Also do you take the high road or the low road...??? Link to comment https://www.fordxr6turbo.com/forum/topic/52357-how-much-power-before-changing-internals/#findComment-783575 Share on other sites More sharing options...
davidald Me Donating Members 360 Member For: 18y 1m 6d Gender: Male Location: Adelaide Posted 10/12/08 12:23 PM Share Posted 10/12/08 12:23 PM I always thought a blower in Scotland was a guy with bagpipes. oops spam! Link to comment https://www.fordxr6turbo.com/forum/topic/52357-how-much-power-before-changing-internals/#findComment-784195 Share on other sites More sharing options...
