Finally Got My Ute!
lukexr61988
  • Legendary member!!
  • Member For: 18y 1m 2d
Well no - It wouldnt work as well as a full system otherwise no one would run a full system...
You could probably run just a 4 inch or 3.5 inch (with seperate w/gate pipe) Dump, good hi flow cat and remove the centre muffler to make the power your looking for however, it would probably be at more boost than it would if you had the full system. Obviously the less restriction there is in your exhaust the better and if you dont get the full system your just pushing the restriction further down your exhaust and further from the engine... This isnt exactly a bad thing but it isnt exactly perfect either.
If your going for 350 first, just get the mods you need for that and if ya need to get a plenum and surgetank at a later date to chase more then that's fine. What you ideally want to avoid is doing a mod and then having to upgrade that mod with better parts further down the line.
  • Member For: 16y 6m 7d
well iv just got back from seen the guys at c v performance, ok firsty they said I definatly should get a surge tank, and they said I would be better of going with a process west kit, they advised if I wasnt to get the full street plenum kit too go for the process west stage stage too with the underbattery cai, now my questions are do I really need the surge tank? as a few of you guys say its not a must for now, and I thought the under battery cai wasnt as good as the inbox like on the rapid systems v3.5, for all parts and install and including tune is going to cost me near 10grand does this sound right because I thought to see 350 rwkw could be done for a bit less then that, any advice or help will be greatly appreciated, cheers
  • 1 month later...
  • Member For: 17y 7m 30d
Congrats on your new ride...as for power its never enough... :slap:
And if you want to save some money, try installing some of things yourself or a friend that knows what his doing...
Edited by xr6t_ute
  • Member For: 18y 8m 29d
you dont need a surge tank in the utes,I just run the walbro intank,have been running 380rwkw+ over 100passes at the track and its never surged once,even low on fuel which I wouldnt advise!!hope this helps good luck with the mods should go hard!!!!
cheers lee
Edited by dalts
  • Forged Member
  • Member For: 18y 17d
Surge tanks aren't generally a necessity for drags, but on the circuit and during hill climbs/spirited twisty driving it is good insurance.
I didnt end up getting this ute, the D**KH**D pulled out on the day that I was meant to pick it up, but a few weeks after that found an bought a 6/06 build bf ute in black, already started the mods, got one of rapids v3.5 kits installed last week, and have bought a full S/S xforce exhaust, siemens deka injectors n will be getting installed by cv hopfuly in a month with the rest of my mods and for the pump, iv decided I will just be going with a walbro intank and ill see how that goes
