redragon Member 5 Member For: 17y 5m 24d Gender: Male Location: Frankston Posted 03/12/08 07:51 AM Share Posted 03/12/08 07:51 AM Hey, Just wondereing when I turn my standerd radio/cd's up, they automatically reduce in sound. so if I turn up the bass the volume gets turned down by itself. I dont have standered speakers either. Link to comment https://www.fordxr6turbo.com/forum/topic/52184-this-may-be-stupid/ Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 2m 7d Gender: Male Location: Brisbane Posted 03/12/08 08:27 AM Share Posted 03/12/08 08:27 AM Have you got power limiting or CD compression turned on? Link to comment https://www.fordxr6turbo.com/forum/topic/52184-this-may-be-stupid/#findComment-779887 Share on other sites More sharing options...
redragon Member 5 Member For: 17y 5m 24d Gender: Male Location: Frankston Posted 03/12/08 08:33 AM Author Share Posted 03/12/08 08:33 AM (edited) I dont know lol.let me explain myself a bit better, as I was in a rush with the last post.when I had 4 standard speakers, when I turned the radio or cd's up, pretty loud, the Radio and Cd's automatically reduce in volume by them selves. I had bought new 4 speakers, installed them, and it still does it. I really dont want to buy a head unit either. its just annoying, you want to enjoy your song and let everybody else enjoy it too, but it just turns itself down. Also is it possible to install an Amp and/or sub going off the standard Headunit?Thanks in advance Edited 03/12/08 08:36 AM by redragon Link to comment https://www.fordxr6turbo.com/forum/topic/52184-this-may-be-stupid/#findComment-779891 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 2m 7d Gender: Male Location: Brisbane Posted 03/12/08 08:38 AM Share Posted 03/12/08 08:38 AM Yeah I got you the first time...check to see if either of those things are turned on before going any further. Hopefully it's just a setting on your stereo. From the manual...Power LimitingRotate the volume control counter clockwise to enable power limitingand counterclockwise to disable Power limiting. Power limiting is afeature that limits the amount of distortion at high volume levels to lessthan 10% THD (total harmonic distortion). The unit will, when it detectsthat the signal is distorted, reduce the volume thereby maintaininghigh quality sound at all volume levels. This feature can be disabled,which will enable the volume to be increased, but at a higher level ofdistortion.CD Compression (where fitted)CD compression reduces the dynamic range of the CD by reducingthe amplitude of high level signals and increasing the amplitude of lowlevel signals. Compression is useful in car audio systems when thedynamic range of CD’s exceeds that of the listening environment. Atypical car audio system will play a maximum level of about 105dBSPL (Sound Pressure Level). Road and engine noise at 100 km/h canbe around 70dB SPL, leaving an acoustic dynamic range in-vehicle of35dB SPL. On a CD with a dynamic range of 80dB, the soft passagesof the disc will not be audible above the acoustic road and enginenoise. By compressing the CD signal and more closely matching thedynamic range of the vehicle, quiet passages can once again beheard. Rotate the volume control clockwise to enable compressionand counter clockwise to disable compression. Link to comment https://www.fordxr6turbo.com/forum/topic/52184-this-may-be-stupid/#findComment-779895 Share on other sites More sharing options...
redragon Member 5 Member For: 17y 5m 24d Gender: Male Location: Frankston Posted 03/12/08 08:49 AM Author Share Posted 03/12/08 08:49 AM and when do I turn the knob? when the radio is off? Link to comment https://www.fordxr6turbo.com/forum/topic/52184-this-may-be-stupid/#findComment-779902 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 2m 7d Gender: Male Location: Brisbane Posted 03/12/08 08:53 AM Share Posted 03/12/08 08:53 AM In the same menu as bass, treble, fade etc...So press the menu button until it appears Link to comment https://www.fordxr6turbo.com/forum/topic/52184-this-may-be-stupid/#findComment-779911 Share on other sites More sharing options...
animalxr6t Member 186 Member For: 17y 5m 22d Gender: Male Location: riverland south aus Posted 03/12/08 10:09 AM Share Posted 03/12/08 10:09 AM im surprised u havnt seen this wen adjusting base and wat not. its in with those settings. bass trebble balance CD COMP POWER LIMITING. Link to comment https://www.fordxr6turbo.com/forum/topic/52184-this-may-be-stupid/#findComment-779969 Share on other sites More sharing options...
sicklaser Member 183 Member For: 18y 9m 23d Location: Mackay QLD Posted 03/12/08 08:28 PM Share Posted 03/12/08 08:28 PM just leave the power limiting on. its only going to sound horrible any louder because the system has run out of power to drive the speakers. Link to comment https://www.fordxr6turbo.com/forum/topic/52184-this-may-be-stupid/#findComment-780149 Share on other sites More sharing options...
Butto Member 352 Member For: 17y 2m 10d Gender: Male Location: Kellyville, Sydney Posted 04/12/08 11:11 PM Share Posted 04/12/08 11:11 PM How f*cking loud do u need it to be? If I turn up my standard system up to about 25 its pretty much unbearable Link to comment https://www.fordxr6turbo.com/forum/topic/52184-this-may-be-stupid/#findComment-780931 Share on other sites More sharing options...
sicklaser Member 183 Member For: 18y 9m 23d Location: Mackay QLD Posted 06/12/08 02:55 AM Share Posted 06/12/08 02:55 AM with my power limiting on or off about 18 is as high as it goes before it sounds bad. the power limiting just wont let it get any louder. but it was never loud and quailty enough so I upgraded the whole system Link to comment https://www.fordxr6turbo.com/forum/topic/52184-this-may-be-stupid/#findComment-781507 Share on other sites More sharing options...
