  • Member For: 18y 8m 24d
Hi all...hope someone can help
I've noticed marks on the transparent perspex screen in front of the main instrument panel gauges. At some angles of the light it can be quite noticeable and it is starting to really bug me. I've tried to gently wipe them away from the outside but I think that they are on the inside surface. I would like to have a go at removing the perspex screen only if it is relatively easy and I don't stuff the whole thing up.
I've noticed three screws on the underside of the cowling above and in front of the screen. If this is where I make a start, how many more steps are there in removing the screen. If someone has already attempted this, can you give me the steps on how to get the screen out and then back in again. Any guidance would be most appreciated.
https://www.fordxr6turbo.com/forum/topic/52133-main-instrument-panel/
  • Mmmmm......BOOST
  • Member For: 18y 1m
have'nt done a ba but other fords I've had ,those screws just released the molding around the screen , plus a few more bit's and pieces needed removing then pull whole unit out and remove gauges etc from the back and last of all get to the screen not an easy job
  • iTs alL DaRDy........
  • Member For: 17y 8m 23d
yeah mate 3 screws up top then, drop the steering colomb and wigth a long pbhillips head thdere is one either side of the colomb behind the rubber thing between the dash and the colomb. remove these and it will pull out and tilt down, then undo the wiring connectors and the whole instrument cluster comes out. usually the front piece including the clear plastic either unclips or unscrews. be carefukll not to touch the gauges as the mat black loves finger marks and they are a bitch to get off. if u do put finger marks, gently wipe with rubbing alcohole
goodluck
  • Member For: 18y 4m 14d
Just curious if it leaves a fault code in your ecu showing it has been tampered with?
Been wanting to fit a FPV facia to my cluster but havn't done so because of this fault code.
  • Mmmmm......BOOST
not sure but if you fitted a different dash it would have to log something ,how does the km's done thing work on these if you put a new dash in would it read 0 km's or what was on the old one ?
  • ORSM Ford Cruisers!
  • Member For: 19y 11m 28d
No codes registered when replacing the cluster, You can get a new perspex screen from ford about $50-60 Part Number BA 10887A.
Thanks ORMSBA
Not worried about the cost...
Just don't want to stuff the dashboard (the wife will kill me for "F"ing around with it.
But it really bugs me when at some angles of the light you can see marks that you can't get to.
The average person probably won't notice but I know its there...arrrrgh!!
If you were in melbourne, I charge $60 to replace the screen and check calibration.
