  • A much better forum
  • Silver Donating Members
  • Member For: 16y 9m 16d
Just wanted to work out. Can Boost levels be controlled by an edit... (ie. can it be set to 16psi using a capa flash???)
I assumed this is how it was done, as I have two tunes on my box, 13psi and 16psi... So it MUST be controllable by an edit???
I thought this was how it was done, but someone who was working on my car today thought you had to control it manually... ie. a boost switch.
Can someone please clarify???
Worm
https://www.fordxr6turbo.com/forum/topic/52045-boost-control-how-ecu/
  • Cryptic Clothing Company
  • Member For: 16y 9m 29d
yeh, I was under the impression boost was colltrolled by the edit.. it is possible to up the boost via a boost T but not sure on how good that wud b..
I have a street ford mag, which is based on turbos, but it says in there that they couldn't control boost via a manual boots controller, as the Ford Computer stops you from winding up the boost... Basically doesn't allow enough fuel for higher boost..???
I have that same magizine.. yeah so did the guy touching your car.. upped the boost for u?
  • Mmmmm......BOOST
  • Member For: 18y 11d
no no no it needs to be done through the flash tune
manual boost control can work to a degree but if the ecu hasn't been programmed to deal with those boost levels you will have nothing but dramas or a dead car
that's what I said... You cant use a manual boost control... and it must be done through the ECU... :-)
  • Mmmmm......BOOST
yeh things like the e-boost work but the car needs to be tuned to the maximum boost levels then you can dial the boost back with the e-boost controller and the car will take it
  • Member For: 21y 8m 5d
I'm sure I just read that someone on here has a manual boost T bar thingy and runs around 15psi normally and 23psi for drag. Obviously ecu tuning is required but he says it works great and at $100 for the manual control that cheap.
  • Member For: 21y 10d
that's right as long as it has been tuned to the max boost first via Edit , you can run at lower boost than max via a manual boost controller.
  • Member For: 19y 1m 15d
I have run a manual boost controller/bleed valve, $50 from supercrap. must be used with the edit.
I used mine to pull back the power on a 100% everything max generic tune.
worm if you get a bleed valve you will be able to reduce your boost level without reflashing, mabee even find a happy point between wheelspin and back in seat power.
Edited by BFHOON
