Worm A much better forum Silver Donating Members 3,808 Member For: 16y 9m 20d Gender: Male Location: Victoria Posted 27/11/08 07:47 AM Share Posted 27/11/08 07:47 AM Just wanted to work out. Can Boost levels be controlled by an edit... (ie. can it be set to 16psi using a capa flash???)I assumed this is how it was done, as I have two tunes on my box, 13psi and 16psi... So it MUST be controllable by an edit???I thought this was how it was done, but someone who was working on my car today thought you had to control it manually... ie. a boost switch.Can someone please clarify???Worm Link to comment https://www.fordxr6turbo.com/forum/topic/52045-boost-control-how-ecu/ Share on other sites More sharing options...
typhoon_freak Cryptic Clothing Company Donating Members 4,556 Member For: 16y 10m 3d Gender: Male Location: Brisvages, Capalaba Posted 27/11/08 07:54 AM Share Posted 27/11/08 07:54 AM yeh, I was under the impression boost was colltrolled by the edit.. it is possible to up the boost via a boost T but not sure on how good that wud b.. Link to comment https://www.fordxr6turbo.com/forum/topic/52045-boost-control-how-ecu/#findComment-776333 Share on other sites More sharing options...
Worm A much better forum Silver Donating Members 3,808 Member For: 16y 9m 20d Gender: Male Location: Victoria Posted 27/11/08 08:03 AM Author Share Posted 27/11/08 08:03 AM I have a street ford mag, which is based on turbos, but it says in there that they couldn't control boost via a manual boots controller, as the Ford Computer stops you from winding up the boost... Basically doesn't allow enough fuel for higher boost..??? Link to comment https://www.fordxr6turbo.com/forum/topic/52045-boost-control-how-ecu/#findComment-776354 Share on other sites More sharing options...
typhoon_freak Cryptic Clothing Company Donating Members 4,556 Member For: 16y 10m 3d Gender: Male Location: Brisvages, Capalaba Posted 27/11/08 08:05 AM Share Posted 27/11/08 08:05 AM I have that same magizine.. yeah so did the guy touching your car.. upped the boost for u? Link to comment https://www.fordxr6turbo.com/forum/topic/52045-boost-control-how-ecu/#findComment-776358 Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 18y 15d Gender: Male Location: central coast Posted 27/11/08 08:31 AM Share Posted 27/11/08 08:31 AM no no no it needs to be done through the flash tune manual boost control can work to a degree but if the ecu hasn't been programmed to deal with those boost levels you will have nothing but dramas or a dead car Link to comment https://www.fordxr6turbo.com/forum/topic/52045-boost-control-how-ecu/#findComment-776432 Share on other sites More sharing options...
Worm A much better forum Silver Donating Members 3,808 Member For: 16y 9m 20d Gender: Male Location: Victoria Posted 27/11/08 08:38 AM Author Share Posted 27/11/08 08:38 AM that's what I said... You cant use a manual boost control... and it must be done through the ECU... :-) Link to comment https://www.fordxr6turbo.com/forum/topic/52045-boost-control-how-ecu/#findComment-776446 Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 18y 15d Gender: Male Location: central coast Posted 27/11/08 09:02 AM Share Posted 27/11/08 09:02 AM yeh things like the e-boost work but the car needs to be tuned to the maximum boost levels then you can dial the boost back with the e-boost controller and the car will take it Link to comment https://www.fordxr6turbo.com/forum/topic/52045-boost-control-how-ecu/#findComment-776477 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 8m 9d Gender: Male Location: Townsville Posted 27/11/08 03:02 PM Share Posted 27/11/08 03:02 PM I'm sure I just read that someone on here has a manual boost T bar thingy and runs around 15psi normally and 23psi for drag. Obviously ecu tuning is required but he says it works great and at $100 for the manual control that cheap. Link to comment https://www.fordxr6turbo.com/forum/topic/52045-boost-control-how-ecu/#findComment-776859 Share on other sites More sharing options...
rboksic Donating Members 514 Member For: 21y 14d Posted 02/12/08 05:57 AM Share Posted 02/12/08 05:57 AM bjc said: I'm sure I just read that someone on here has a manual boost T bar thingy and runs around 15psi normally and 23psi for drag. Obviously ecu tuning is required but he says it works great and at $100 for the manual control that cheap.that's right as long as it has been tuned to the max boost first via Edit , you can run at lower boost than max via a manual boost controller. Link to comment https://www.fordxr6turbo.com/forum/topic/52045-boost-control-how-ecu/#findComment-778948 Share on other sites More sharing options...
BFHOON Donating Members 1,932 Member For: 19y 1m 19d Gender: Male Location: nsw Posted 02/12/08 06:18 AM Share Posted 02/12/08 06:18 AM (edited) I have run a manual boost controller/bleed valve, $50 from supercrap. must be used with the edit.I used mine to pull back the power on a 100% everything max generic tune.worm if you get a bleed valve you will be able to reduce your boost level without reflashing, mabee even find a happy point between wheelspin and back in seat power. Edited 02/12/08 06:20 AM by BFHOON Link to comment https://www.fordxr6turbo.com/forum/topic/52045-boost-control-how-ecu/#findComment-778965 Share on other sites More sharing options...
