R-SPEC You are a dead set goose Silver Donating Members 3,968 Member For: 19y 2m 10d Gender: Male Location: Melbourne Posted 07/12/08 10:59 PM Share Posted 07/12/08 10:59 PM My car vibrates like hell from the rear at 100+kph and has only done so since Ford replaced my diff bush and the other two bushes either side of it. Would you think the vibration is from the different bush or could it possibly be the bearings as mentioned above? Link to comment Share on other sites More sharing options...
TEDracing Member 321 Member For: 16y 6m 14d Gender: Male Location: in a house or shed Posted 07/12/08 11:08 PM Share Posted 07/12/08 11:08 PM I think that's a reasonable price considering they would've more than likely dropped the rear cradle which can take some time Well they had to drop the cradle as the bearings were done aswel. side note do you know if the diff centres are prone to being noisy? had the bearings done at 110k which were making noise at 80-100kmphr quite loud that you could here in the cabin over a low volume stereo. after bearings bushes done still have noise but its not as noisy. the mechanic wasnt to happy as he said the centre looked perfect compared to some hes seen but it had noise. due to that issue he said would give me a good price to do new centre ( higher gears) down the track when I start chasing power.I have seen it sort of mentioned on the forum just wondering is all I can put up with it for now just abit disappointing that its still a young car ( in my eyes) with issues. Link to comment Share on other sites More sharing options...
TEDracing Member 321 Member For: 16y 6m 14d Gender: Male Location: in a house or shed Posted 07/12/08 11:12 PM Share Posted 07/12/08 11:12 PM My car vibrates like hell from the rear at 100+kph and has only done so since Ford replaced my diff bush and the other two bushes either side of it. Would you think the vibration is from the different bush or could it possibly be the bearings as mentioned above? Hi R SPECMy guess would be wheel bearings not diff bearings to give you the shakes but im no expert. Also have you looked at your rubber? If the tyres start to de-laminate (fall apart from the carcase ) they would give you wobble/ shakes aswel. I would get that checked out though, for sure Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 2d Gender: Male Location: SW Sydney Posted 07/12/08 11:31 PM Share Posted 07/12/08 11:31 PM Yeah mate, the BAs did have a bit of whiney diff issues, I don't think there is a great deal you can do about it, I know of a bloke that went through 7 diffs to not have the issues fixed! Link to comment Share on other sites More sharing options...
Full Monty Member 513 Member For: 17y 7m 17d Gender: Male Location: Melbourne Posted 08/12/08 02:08 AM Share Posted 08/12/08 02:08 AM When you replace the main diff bush with a nolathane equivalent, noise levels in cabin does increase, due to the nolathane being a stiffer material therefore transmitting noise / mechanical vibration directly into the chassis. The reason Ford engineered the rear bush to be so soft, is to mask this noise.R-spec, not sure about your vibration, sounds a little worse than just the usual diff whine? Perhaps the rear cradle hasnt been re-aligned correctly. A special tool must be used to ensure the cradle is re-fitted square with the chassis. Link to comment Share on other sites More sharing options...
R-SPEC You are a dead set goose Silver Donating Members 3,968 Member For: 19y 2m 10d Gender: Male Location: Melbourne Posted 08/12/08 02:51 AM Share Posted 08/12/08 02:51 AM Yeah sounds like it could be that. Thanks Gav, I'll get em to check it next service Link to comment Share on other sites More sharing options...
XRSics Donating Members 325 Member For: 16y 4m 3d Gender: Male Location: Melbourne Posted 08/12/08 10:56 AM Author Share Posted 08/12/08 10:56 AM What did that one cost you TED?nothing thank f***. it was in cos it ran out of warranty that day and I was trying to milk it for all its worth. that's why I thought BONZA wen the test drive dude took it for a drive and said theyd replace em all with the "new ones" Link to comment Share on other sites More sharing options...
