  • Member For: 18y 1m 30d
  howitzer85 said:
I've got an '05 BA with stock springs and have only just starting to have problems at 322kW but I still have the stock cat, I'm hoping they'll come good once I fix that.
I've been told its a bit of pot luck as to whether you need valve springs or not so it might be worth waiting till you actually encounter problems...
is that 322rwkw? :spit:
  • Member For: 17y 1m 6d
Hey all I have an 03 as well what is the fail rating on the springs 200rwkw or 250rwkw???
I am running 215rwkw and want to add alot more mods like Injectors, CAPA Flash, Fuel Pump should the Valves be done first? :spoton:
  • Forged Member
  • Member For: 18y 4m 4d
Some go earlier than others mate, generally once the car is tuned with injectors your tuner will be able to find the limit of the BA springs, budget around $900 for supply and install - sometimes its cheaper, but that used to be the going rate...
  • Member For: 17y 3m 16d
I think your right depends on the car I have an 04 auto with stock springs and its running 305rwkw at 15 psi :innocent:
  • Member For: 17y 3m 8d
moral of the story is, every car, every set of springs and every tune is different. Do your mods and get your tune, if at the time your tuner says you need valve springs, get them done then. There is no set rwkw figure that these springs to letgo..from this forum it could be anything from 250-350>rwkilla wasps
Edited by ravenhard
