senna_T Forged Member Lifetime Members 15,818 Member For: 18y 1m 4d Gender: Male Location: SW Sydney Posted 24/11/08 12:07 PM Author Share Posted 24/11/08 12:07 PM Timing gear like this one Danny? This motor also needs the new timing chain guides, and needs valves on the intake side as it came out of time slightly. The head is in good condition though, luckily... Link to comment Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 6m 8d Gender: Male Location: Townsville Posted 25/11/08 03:28 AM Share Posted 25/11/08 03:28 AM Will the traction control coming on do the same thing with its jerking on and off? Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 1m 4d Gender: Male Location: SW Sydney Posted 25/11/08 03:31 AM Author Share Posted 25/11/08 03:31 AM Yes, that can lead to a similar situation, however the shock loading on the gears may not be as extreme in that case, because generally the traction control will cut in at lower engine speeds, rather than on the 6000rpm limiter. While this may not be as dangerous, there is still some risk. I would recommend turning TC off if you are going to be driving hard and expect to loose some traction Link to comment Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 6m 8d Gender: Male Location: Townsville Posted 25/11/08 05:27 AM Share Posted 25/11/08 05:27 AM Thanks senna, will do. Link to comment Share on other sites More sharing options...
Headsex Donating Members 2,528 Member For: 19y 7m 1d Gender: Male Location: Melb Posted 25/11/08 08:46 AM Share Posted 25/11/08 08:46 AM Timing gear like this one Danny? This motor also needs the new timing chain guides, and needs valves on the intake side as it came out of time slightly. The head is in good condition though, luckily...This one was bent.. not quite as f*cked as that one!The cams on this head were good, but the head cam journels.. fail!Its actually turned it into a black paste on the journels.. obviously this ending was not killed when it happened. Link to comment Share on other sites More sharing options...
