Factory Ba Stereo Running 1 Four Channel Amp + 1 Mono Amp For Sub
chris2583
  • Member For: 16y 4m 15d
depends wot alpine amp you are running for the subby. I just installed one and it has high level inputs for off the speaker wires, connected them to the rear speaker wires and it rips!
no noise or interference coming through it at all.
  • Member For: 18y 6m 10d
Yeah my cousin has an amp with the high level inputs and it farken hammers, with just one 12", the bass on -8 and on the factory headunit.... Can hear him coming a mile away.. He really needs to upgrade the speakers though...
  • Member For: 19y 8m 8d
one of your amps will have rca outs so just go from the output of one amp to the input of the other. I'd go from the outputs of the 4 channel to the inputs of the mono.
although, urinal biscuit is on the money, dont bother amping your rear speakers, just bridge the amp and run fronts only of it, will sound much better.
  • Go Pies!!!
  • Member For: 17y 14d
Ok here is one option-
If you have a line (RCA out) on the 4ch amp...
Run the line conv'r to the 4ch amp - then run your fronts and rears from that... connect a pair (or single) rca(s) and run to the input on the 2ch/mono amp which will power your sub...
Easy!
You are best to run a line spliter of your power leads also.... for 15$ far better then running a sinlge fuse to the 1st amp then looping back to the second...
remember your iin the drivers seat therefor wont hear the rears - just leave them as rear fills as others have mentioned above...
its really only worth doing them if you spending $$$$$$ and want it for a reason other then to just say - my rears are done as well...
Edited by smicky
