F6WPN Member 6 Member For: 17y 22d Gender: Male Location: Sydney Posted 06/11/08 07:19 AM Share Posted 06/11/08 07:19 AM Hi all.I have a BA F6, and is leaking alot of oil from the turbo. I pulled the pipe off from the underbattery to the turbo and found quite alot of oil.The car still spools up normal .. does not blow any smoke, I have checked the hose from the rocker cover to the turbo intake and found no oil thinking it might be blow by.Anyone had this problem before?? If it was a seal, shouldnt it blow alot of smoke?CheersDan Link to comment Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 17y 9m 4d Gender: Male Location: central coast Posted 06/11/08 07:48 AM Share Posted 06/11/08 07:48 AM mine generally has about 10-15ml of oil sitting in the inlet of the turbo when I remove the intake pipe Link to comment Share on other sites More sharing options...
F6WPN Member 6 Member For: 17y 22d Gender: Male Location: Sydney Posted 06/11/08 08:13 AM Author Share Posted 06/11/08 08:13 AM I was told that when my cooler was installed, the standard cooler had alot of oil sitting in there...?I dont think this is normal..thanks for your replyDan Link to comment Share on other sites More sharing options...
CaRtZ Member 9 Member For: 16y 2m 10d Posted 21/11/08 10:52 AM Share Posted 21/11/08 10:52 AM be lucky its not an FG, they lea from the block Link to comment Share on other sites More sharing options...
idawina Member 23 Member For: 18y 5m 22d Posted 22/11/08 10:45 AM Share Posted 22/11/08 10:45 AM I wouldnt worry to much. modern turbos pass a small amount of oil past the seals, then it sits in the low spots in the intake piping. as long as it doesnt go making funny noises it should be ok! buts that's just my opinion Link to comment Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 7m 12d Gender: Male Location: Earth Posted 24/11/08 01:27 AM Share Posted 24/11/08 01:27 AM be lucky its not an FG, they lea from the block What leak from the block?I've done 10000kms and haven't got any leaks anywhere. Link to comment Share on other sites More sharing options...
