Gear Shift / Revs Warning Chime
  • Forged Member
  • Member For: 18y 3m 7d
Lol, I drive a MANual remember - any auto I drive gets thrashed*
*disclaimer: said thrashing does not happen in customer or company vehicles.... :blink:
  • Member For: 17y 3m 28d
There is a bloke around the forums either here or fordforums.com.au that knows how to hack into the cluster with a scantool to turn it on.
  • Mad Scientist
  • Member For: 20y 5m 15d
cant remember his name exactly (it mite be xpression??) but hes on fordmods.com to, he was the one that did the big "scantool fun" thread.
is that the same bloke you are thinking of?
Edited by Mr Man
  • NOT THERE!... THERE!
  • Member For: 17y 22d
Is he one of the ORSM guys?
There's a big group of them and I seem to remember him being one of 'em.
Could be wrong though.
Just did a quick search on fordforums.com.au the blokes name is auMatt.
The below is a bit from this thread: http://www.fordforums.com.au/showthread.ph...highlight=chime
The Clone will do all the diagnostics you want, dont expect much from a BA, very limited monitoring is available. BF has alot more.
As for cluster stuff here is what can be altered via obd,
Odo(if less cluster is less than 100km and/or has been reset 3 times already),
Traction warning light,
Hill climb/diff lock light,
DSC Light,
shift alert(must be a fpv cluster)
Brake Fail(Either BA or BF style)
ABS Fail (either BA or BF Style)
Seatbelt Reminder
Police Mode
Body/Fuel Map(Have to figure out how to do multi line messages)
What requires a full EEPROM program,
Body/Fuel Map(The only way I know how to do it at moment)
Shift Alert on non fpv cluster
Odometer at any point.
Speedo change
Tacho Change
Auto Lights alarm
etc
I hope that helps.
Matt
Here's his site: http://ford.degabrielle.com.au/
  • 8 months later...
  • Member For: 19y 11m 4d
Police mode gives you a digital speed readout where the trip counters would usually be (at least on the high series cluster), there is also a speed compare/capture mode with the police mode but I haven't played with that feature.
