  • Member For: 22y 3m 5d
  Quote
A small number of BA I6 engines (including turbos) built between Feb 10th and March 8th 2003 were built with crankshaft sprockets that contained an incorrect nickel content. This can lead to failure of the sprocket under high load conditions and extensive damage to valve train components.
If you have an I6 equipped vehicle built within the date range above it would be wise to contact your dealer for remedial action. Inspection will take 45 minutes and repair (if required) 3-4 hours.
Has everybody seen the above post on Ford Forums?
Thread at Ford Forums
I phoned Westpoint and it appears my car is affected, it goes in Friday for the fix :(
This post is also worth a read:
  Quote
The owners of the effected vehicles are NOT being notified by Ford regarding this concern. They are waiting until the vehicle is presented for service at the dealers. If you care to check your vehicle yourself then try the following.
Look on the timing cover of the engine where the power steering pump mounts to it. You will see a number like 13A03 MB. This is the hot test date code. The first 2 digits represent the Day, The letter represents the Month,The second 2 digits represent the Year. Disreguard the last 2 letters.
This means that if your date is between 10B03 (10th Feb 03) and 08C03 (8th Mar 03) GET YOUR VEHICLE TO YOUR DEALER ASAP!!
https://www.fordxr6turbo.com/forum/topic/5119-timing-sprocket-problem/
  • Brendan Dennis
  • Member For: 22y 6m 17d
Just checked mine. It is a March build, the date stamp on the engine is 13C03JO. So it looks like I am fine.!! (glad of that!)
I just made a quick phone call to the dealer to verify that mine was effected, I'm not too sure of the accuracy of those dates I posted.
I dropped the car in tonight, Westpoint have only just received the new sprockets in yesterday, they are getting ready to start replacing a few I think.
  • 2 months later...
  • Member For: 21y 11m 21d
Blissfully unaware of this problem, I went to my dealer to have the heat shields tightened ( again ) and I was told of the two probs ( sprocket & steering ).
The boys @ Brad Garlick did a great job & My car was ready that day.
Next morning I fire the beast up & hear the worst noise.. It sounded like it had no oil in it. I popped the bonnet & it sounds like it is coming from the p/s pump ???
I drove straight to the dealer to let them have a listen, but just like a sore tooth at the dentist the noise was not apparent. They checked the oil level and it was spot on. What I have found is that The noise goes away when the engine has warmed up ( 15-20 mins )..
The service mgr suggested that I leave the car with them o/nite so they can reproduce the noise on a cold start up.
Has any one experienced this ?? I am wondering if on of the ancilliaries has been damaged in the timing sprocket changeover.
Any ideas??
Cheers
PSI <_<
Hi guys,
1axr - stock standard no modifications
brother of - the dealer has been very good. I cannot fault their efforts to rectify the problem. In regards to the noise is `sounds` like a tappet with too much clearance.
Cheers
PSI
