  • Member For: 18y 1m 5d
I've got a process west stg1 intercooler and it fits between the intercooler and a/c condenser.. if its mounted up the top, as down the bottom the cooler gets very close to the condenser.
But at first I mounted it in the drivers side of the front bumper and had a thermo fan attached to it.
  • Member For: 21y 7m 15d
Mine is fitted the same as Kissy's but without a thermo fan. Car doesn't seem to get any hotter and I assume there is air flow through the fog light.
  • THE PSYCHO XRT
  • Member For: 19y 4m 11d
  • Gender: Not Telling
Its always a good idea to have a Transmission cooler if your using your car for towing purposes or even if you have a high powered T.
Anyways, I also had my PWR Heavy Duty T/Cooler installed in between the A/C Condenser and the IC but later got it mounted on the drivers side,
just like kissy has above. ^^
  • Mmmmm......BOOST
  • Member For: 17y 11m 22d
I have a heavy duty one mounted up behind the left rear wheel ,there is a large open area there plenty of room to mount with a thermo fan ,costs a little more to run the braided lines to the back ,but it is in a nice open spot with no airflow restrictions
