EXIT Member 41 Member For: 18y 5m 23d Location: Brisbane Posted 28/10/08 08:35 AM Share Posted 28/10/08 08:35 AM Hi Guys,I am currently fabricating a 100mm intake setup for my high mount turbo and have had to remove the plastic resevoir on the p/steering pump to get the necessary room.I have had a p/steering reco shop fit a 5/8" hose fitting to the inlet port so I can use a remote resevoir- just wondering if anyone who has done this can tell me what resevoir they used or where I can get one?I seem to recall reading that the XR8 has a remote res? Ideally I would like a nice shiny alloy one.Also I need to replace the radiator expansion bottle with an allow one so it doesn't melt- ( see attached photo)Does anyone other than PWR make one? Link to comment https://www.fordxr6turbo.com/forum/topic/51125-remote-psteering-resevoir/ Share on other sites More sharing options...
ETM Member 1,194 Member For: 18y 3m 7d Gender: Male Location: syd south Posted 28/10/08 09:22 AM Share Posted 28/10/08 09:22 AM Mate you could easily run 4" pipe off the front of that turbo without relocating the p/s reservoir, what you will really need is to relocate the radiator overflow tank as the manifold you have as the turbo sitting way too close to the tank that imo even using an alloy tank you will still boil the water. Link to comment https://www.fordxr6turbo.com/forum/topic/51125-remote-psteering-resevoir/#findComment-756979 Share on other sites More sharing options...
EXIT Member 41 Member For: 18y 5m 23d Location: Brisbane Posted 28/10/08 10:07 AM Author Share Posted 28/10/08 10:07 AM Yeh I possibly could have kept the ps resevoir but removing it made it easy to use a standard 90 degree mandrel bend to come around into where the battery normally sits and make an air box with a pod filter in it. It will be pretty neat.I am a little concerned about the close proximity of the water tank to the turbo but with a turbo cozy bag and some sheilding I'm hoping it will be ok. Link to comment https://www.fordxr6turbo.com/forum/topic/51125-remote-psteering-resevoir/#findComment-757047 Share on other sites More sharing options...
Full Monty Member 513 Member For: 17y 11m 28d Gender: Male Location: Melbourne Posted 30/10/08 02:22 AM Share Posted 30/10/08 02:22 AM Good luck keeping paint on your bonnet...=) Link to comment https://www.fordxr6turbo.com/forum/topic/51125-remote-psteering-resevoir/#findComment-758546 Share on other sites More sharing options...
Dirty32 Legendary member!! Donating Members 1,739 Member For: 18y 4m 29d Gender: Male Location: Dianella, West Oz Posted 30/10/08 03:45 AM Share Posted 30/10/08 03:45 AM Turbo cozy bag meaning Turbo beanie?If so, lots of info on here as to why this is not a good idea dude...Other than that, im not sure why you havent spoken with any of the site sponsors about making a Airbox/Custom Pod to turbo pipe to suit your application/measurements etc... Might be something to think of? Link to comment https://www.fordxr6turbo.com/forum/topic/51125-remote-psteering-resevoir/#findComment-758591 Share on other sites More sharing options...
EXIT Member 41 Member For: 18y 5m 23d Location: Brisbane Posted 03/11/08 02:02 AM Author Share Posted 03/11/08 02:02 AM Dirty32 said: Turbo cozy bag meaning Turbo beanie?If so, lots of info on here as to why this is not a good idea dude...Other than that, im not sure why you havent spoken with any of the site sponsors about making a Airbox/Custom Pod to turbo pipe to suit your application/measurements etc... Might be something to think of?That's interesting, I will read up on the turbo beanie thing.I sorted the PS resevoir. PWR make one for the LS1 which is nearly perfect and they are making me one with a different mount to suit my needs. Got the expansion tank from them also.I am fabricating all the induction pipework myself as well as the hotside piping. I bought a process west kit and the IC to plenum setup is great but the hot side obviously doesn't suit my setup so I've fabricated a 2.5 inch stainless mandrel bent setup which goes from the turbo under the battery cradle to the IC - pretty slick too if I do say so myself :-)The induction piping is pretty simple- 4" 90 degree bend witha couple extensions and hose fittings. It comes staight round from the turbo into the battery area ,which will be enclosed to make an air box, and a 4" K&N pod filter sits in there nicely.Does anyone know of a supplier who makes an air box setup for the battery compartment standard?Probably all custom built I expect? I can build one but it would save a heap of drama if I could buy one and adapt it if necessary. Link to comment https://www.fordxr6turbo.com/forum/topic/51125-remote-psteering-resevoir/#findComment-761135 Share on other sites More sharing options...
Guest Guests Posted 03/11/08 02:06 AM Share Posted 03/11/08 02:06 AM Plazmaman, Process West, Nizpro, Rapidsystems... The list goes on! Link to comment https://www.fordxr6turbo.com/forum/topic/51125-remote-psteering-resevoir/#findComment-761138 Share on other sites More sharing options...
EXIT Member 41 Member For: 18y 5m 23d Location: Brisbane Posted 03/11/08 02:11 AM Author Share Posted 03/11/08 02:11 AM ETM said: Mate you could easily run 4" pipe off the front of that turbo without relocating the p/s reservoir, what you will really need is to relocate the radiator overflow tank as the manifold you have as the turbo sitting way too close to the tank that imo even using an alloy tank you will still boil the water.ETM I saw some photos in the parts for sale of one of your manifolds for a T51R- looks very nice mate! It's quite similar to mine by the look but from the photos looks like the turbo is rocked over a little closer to the head- is that right? Link to comment https://www.fordxr6turbo.com/forum/topic/51125-remote-psteering-resevoir/#findComment-761142 Share on other sites More sharing options...
Guest Guests Posted 03/11/08 02:15 AM Share Posted 03/11/08 02:15 AM That engine bay pic makes the turbo look Extremely close to the overflow tank! Even an ally one will be no good to you as the coolant will just be cooked after a few power runs!! Link to comment https://www.fordxr6turbo.com/forum/topic/51125-remote-psteering-resevoir/#findComment-761145 Share on other sites More sharing options...
