Butto Member 352 Member For: 17y 19d Gender: Male Location: Kellyville, Sydney Posted 21/10/08 07:41 PM Share Posted 21/10/08 07:41 PM hey everybody, As some of you know I upgreded my suspension and wheels a bit lately. came out with 19x8 fronts n 19x8.5 rears, lowered 2inches at the rear with reset leaves and new springs and 1 inch at the front with new springs, also threw in front n rear sway bars.The problem I have now is when I take off I get a pretty loud (from inside the ute) creaking sound that seems to be coming from the rear left of the car. It only started in the last 1 or 2 weeks and ive had the mods done for about a month n a half now.Any body know what could be causing it? Its only when im going from stop to start, or going slow over bumps n stuff.Any help is much appreciated Cheers Butto Link to comment https://www.fordxr6turbo.com/forum/topic/50940-rear-end-creak-after-lowering/ Share on other sites More sharing options...
typhoon_freak Cryptic Clothing Company Donating Members 4,556 Member For: 16y 10m 1d Gender: Male Location: Brisvages, Capalaba Posted 21/10/08 07:46 PM Share Posted 21/10/08 07:46 PM this has happened to my old ute and my mates.. the leafs are rubbing together. we fixed it by cutting up a rubber tube from a bike tyre and sliding it in between the leafs that were moving Link to comment https://www.fordxr6turbo.com/forum/topic/50940-rear-end-creak-after-lowering/#findComment-753591 Share on other sites More sharing options...
RowdyBurns Donating Members 641 Member For: 17y 2m 3d Gender: Male Location: Brisbane Posted 21/10/08 09:56 PM Share Posted 21/10/08 09:56 PM I had the same thing happen to mine, my issue was that the nut and bolt at the front of the leaf spring was not tight. Tightened it up and the sound went away. The suspension was only 2 months old when it started. I expect it to come back. For more info see this thread:http://www.fordxr6turbo.com/forum/index.php?showtopic=47338CheersJulian Link to comment https://www.fordxr6turbo.com/forum/topic/50940-rear-end-creak-after-lowering/#findComment-753603 Share on other sites More sharing options...
EDXR8Sprint Member 105 Member For: 17y 7m 15d Gender: Male Location: Melbourne Posted 22/10/08 09:08 AM Share Posted 22/10/08 09:08 AM I get the exact same problem in mine, with stock suspension.Ford fix it every time I take it in for service, reckon the U bolts for the leaves are loose.Been meaning to have a look myself, but when they are fixing it under warranty I find it hard to get the motivation Link to comment https://www.fordxr6turbo.com/forum/topic/50940-rear-end-creak-after-lowering/#findComment-753920 Share on other sites More sharing options...
Iconic Bionic My engine bay is Bionic Donating Members 3,726 Member For: 19y 1m 22d Gender: Male Location: Freeways Posted 24/10/08 10:45 AM Share Posted 24/10/08 10:45 AM Mine always creaks in the wet and Ford have no idea what it is. With a year of warranty "what warranty" left, what is there to do.I.B. Link to comment https://www.fordxr6turbo.com/forum/topic/50940-rear-end-creak-after-lowering/#findComment-755078 Share on other sites More sharing options...
Brand Member 19 Member For: 16y 8m 4d Posted 25/10/08 02:40 AM Share Posted 25/10/08 02:40 AM I got mine lowered and have the same problem... might have to get some loctite threadlocker on the bolts to stop them coming loose Link to comment https://www.fordxr6turbo.com/forum/topic/50940-rear-end-creak-after-lowering/#findComment-755311 Share on other sites More sharing options...
