Jeremy Member 112 Member For: 16y 7m 28d Gender: Male Location: Perth mindaz Posted 20/10/08 06:25 AM Share Posted 20/10/08 06:25 AM hey all,just thought I'd drop my dyno sheets cause I made it into the 300+ club Just a few things I wanna ask some people...Firstly, I was expecting around 350+rwkw... but for some reason the boost was spiking all over the place when it got to about 14psi. I had the actuator changed to a 12pound one for xr6turbo developments, and had the valve springs done etc etc. The guys at BPT reckon it may be my boost solenoid is sticking that's why it was spiking? They controlled it relativly well after about 4 hours on the dyno. But they said if they can get that sorted they should see more power.. any1 with any ideas? Also, My stage 3 PW cooler I put on it has only the stock inlet/outlet sizes so they said that would of been restricting flow which is why I probally didnt get to the 350+ mark...they are gonna re-engineer the cooler to bigger inlet/outlet sizes so hopefully that will fix the flow up a bit.Other than that I was resonably happy with the power and 900+Nm of torque which really made the difference.Also had the Malwood short shifter fitted... feels great a you can slam it into gears.going to take it down to kwinnana this next wednesday to see wat time she runs... hopefully I can get my mickey thompsons in time. Link to comment Share on other sites More sharing options...
rhys86 Donating Members 443 Member For: 17y 11m 12d Gender: Male Location: Wollongong Posted 20/10/08 11:29 AM Share Posted 20/10/08 11:29 AM Doesn't the stage 3 PW cooler have the 3inch outlet which is dlarger than stock?? Link to comment Share on other sites More sharing options...
R-SPEC You are a dead set goose Silver Donating Members 3,968 Member For: 19y 11d Gender: Male Location: Melbourne Posted 20/10/08 11:38 AM Share Posted 20/10/08 11:38 AM Wouldn't the problem be your wastegate? Link to comment Share on other sites More sharing options...
Jeremy Member 112 Member For: 16y 7m 28d Gender: Male Location: Perth mindaz Posted 20/10/08 12:15 PM Author Share Posted 20/10/08 12:15 PM yeh the PW stage 3 does normally have the 3inch outlets but the one I brought was modified from new to suit stock inlet/outlet sizes.. dont ask me why.... but im getting it made to bigger sizes in the coming weeks which should see heaps better flow... the temps are down majorly!!!Im not sure if its a wastegate problem.. the boys at BPT were pretty big on it being the boost solenoid but im going to do that WD-40 trick when I get home (2 days) and see if that fixes it... if it dosnt it prob is a wastegate problem then ay?? im not too clued up on the turbo side of things ay...any1 can shed some more light? Link to comment Share on other sites More sharing options...
Guest Guests Posted 20/10/08 12:34 PM Share Posted 20/10/08 12:34 PM Your wastegate not being ported would cause overboosting if anything, not lack of boost. I'd be guessing it's your cooler inlet/outlet restricting flow & thus power.Porting the wastegate will give you a nice steady boost curve rather than that shaggy one in the first graph Link to comment Share on other sites More sharing options...
The_Bogan Donating Members 881 Member For: 17y 8m 8d Gender: Male Location: Brisbane, Queensland Posted 21/10/08 01:46 AM Share Posted 21/10/08 01:46 AM could be hitting torque limits Link to comment Share on other sites More sharing options...
Worm A much better forum Silver Donating Members 3,808 Member For: 16y 4m 19d Gender: Male Location: Victoria Posted 21/10/08 03:28 AM Share Posted 21/10/08 03:28 AM Nice work.... I have a similar setup and I am getting 335rwkw... I would suggest it may be your wastegate/flapper?I dont have the exhaust, but may do this eventually.335 and 350 wont be much different... 335 may be better for a 1/4 time, as you get so much wheel spin and you would really only make that at 5000+rpm, which is when you are shifting anyway. Link to comment Share on other sites More sharing options...
R-SPEC You are a dead set goose Silver Donating Members 3,968 Member For: 19y 11d Gender: Male Location: Melbourne Posted 21/10/08 05:21 AM Share Posted 21/10/08 05:21 AM 335 and 350 wont be much different... You won't be saying that when you get smoked by one wormy! They're totally different Link to comment Share on other sites More sharing options...
Jeremy Member 112 Member For: 16y 7m 28d Gender: Male Location: Perth mindaz Posted 21/10/08 08:47 AM Author Share Posted 21/10/08 08:47 AM yeh with the parts I have on I should definetly see 350rwkw dont ya guys rekon?I mean theres heaps of cars around that have less parts running the same power... I was just a lil pissed off these guys couldnt work out wat was wrong... I think once the cooler gets fixed I should see the better flow thus giving more power and better boost control?Whats involved in doing the wastegate and flapper? Link to comment Share on other sites More sharing options...
mic Donating Members 1,725 Member For: 16y 10m 23d Gender: Male Posted 21/10/08 10:17 AM Share Posted 21/10/08 10:17 AM yeh get ya flapper bored out mate, then youll get ya 350 easy. great result by the way.oh turbo has to come off, hand it 2 a turbo shop and then just re assemble. Link to comment Share on other sites More sharing options...
